APG 3.6 - Editor grid markings not displayed...
by mediavets » Tue Jul 08, 2014 2:22 pm
APG 3.6 64-bits on Windows 8.1 Pro ...
Grid markings are not displayed when settings configured as shown in the screenshot.
Re: APG 3.6 - Editor grid markings not displayed...
by AlexandreJ » Wed Jul 09, 2014 9:05 am
The field of view of that panorama is really narrow. Can you zoom out and see if some lines appears ?
by mediavets » Wed Jul 09, 2014 9:57 am
AlexandreJ wrote:The field of view of that panorama is really narrow. Can you zoom out and see if some lines appears ?
That was the full extent of the pano image - it was simple test of shooting with a longer (210mm) focal length to investigate DOF at hyperfocal.
Here's a different example with a larger FOV.
You will note that the degree values are not visible of the vertical axis in the Editor.
I seem to recall that they would have been in earlier versions of APG in such circumstances?
by AlexandreJ » Wed Jul 09, 2014 11:54 am
In fact, in your screencopy, we can see the secondary grid, not the primary, as the field of view of the panorama is too small.
Your panorama is -6° / +6° and the primary grid steps are 15°, so the grid itself will only display at -15°, 0°, +15°.
You can still see the secondary grids on the screenshot.
by mediavets » Wed Jul 09, 2014 12:04 pm
AlexandreJ wrote:In fact, in your screencopy, we can see the secondary grid, not the primary, as the field of view of the panorama is too small.
OK - but why do I not see the numeric values in degrees on the vertical axis in this case?:
viewtopic.php?f=19&t=22957&p=145473#p145464
by AlexandreJ » Wed Jul 09, 2014 1:57 pm
Probably because of the projection mode. If you are in spherical projection, it is linear, the distance between 2 lines, horizontally, vertically. On rectilinear, it isn't.
I did try to have a really short fov panorama with your settings. It works.
by mediavets » Wed Jul 09, 2014 2:25 pm
AlexandreJ wrote:Probably because of the projection mode. If you are in spherical projection, it is linear, the distance between 2 lines, horizontally, vertically. On rectilinear, it isn't.
I think there's a misunderstanding.
I am not saying that the gridlines are not displayed I am saying that the numeric values/labels on the vertical axis are not displayed in this case (which does not have a very small FOV):
viewtopic.php?f=19&t=22957&p=145484#p145464
