Finish button in AGP 3.0 & 3.5 import assistant disabled
Abulafia
by Abulafia » Thu Apr 24, 2014 9:23 am
Hi Team,
hi All,
sometimes the finish button in the import assisant is disabled when the number of images does not match the number in the xml-file the first time.
Here is the workflow:
- start import assistant
- select Papywizard
- open xml-file
- select images (number of images doesn't match the number in xml-file)
- next select correct number of images
when all thumbnail images are loaded the finish button sometimes is disabled. In this case you have to start the process again.
This happend in APG 3.0 & APG 3.5.
Regards,
Stefan
Zoobius
Re: Finish button in AGP 3.0 & 3.5 import assistant disabled
by Zoobius » Fri Apr 25, 2014 3:47 pm
Hi Stefan,
So the answer is on your post, the number of images selected doesn't fit with the number of images of the xml file ;) So you can't click on Finish… This is the case when at least one image is missing. Did you remove images from your source folder prior to use the Import wizard in Autopano?
Guillaume - Kolor Technical Support
Quick links: User Account, Documentation, Youtube Channel
Abulafia
by Abulafia » Wed May 21, 2014 9:36 pm
Yes, when I fisrt select the wrong number of images, then the button is disabeled. That's clear because the number of images dosn't macht to the number in the xml-file, but when I select the right number of images and I can see the correct preview. The button is still disabeled. In this case I have to start all over.
