cannot load 3.5 projects into 3.0.8
HansKeesom
by HansKeesom » Thu Feb 06, 2014 2:16 pm
as 3.5 is chrasshing in preview, I want to load the 3.5 generated project into 3.0.8
unfortunately it does not load.
So no way to continu with this project. :-(
Liked in: 128 posts
Re: cannot load 3.5 projects into 3.0.8
by mediavets » Thu Feb 06, 2014 2:38 pm
HansKeesom wrote:as 3.5 is chrasshing in preview, I want to load the 3.5 generated project into 3.0.8
I quote from the Change log - that Alex recommend us to read before using 3.5:
http://www.kolor.com/blog-en/2014/02/03 ... -5-beta-1/
".pano format in full XML. The project file has evolved a lot during the engine revamp and we now have a full XML file format which is more easy to manage over version release. So you won’t be able to reopen 3.5 .pano file with older version. If you need to do that, we added a ‘save as old .pano’ export so you can convert this .pano XML format to an old one. Of course, some aspects cannot be transfered like many parts in the optimizer settings which are totally new."
HansKeesom
by HansKeesom » Thu Feb 06, 2014 3:30 pm
I stand corrected!
Thanks for correcting me ;-)
HansKeesom
by HansKeesom » Thu Feb 06, 2014 4:56 pm
Chrashing solve by changing blending from smart to ISO
