Autopano giga and full frame lense
yvano
by yvano » Wed Jan 15, 2014 8:07 pm
I used to make 360° panoramas with a D300 Nikon and a 10.5 fisheye : I never had problems of detection with Autopano Giga, always a good RMS result...
Now I have a D610 with a 16mm fisheye and I have a lot of problem of detection, some amazing RMS result, it's very strange, is there anything I should adjust in autopano giga when using a full frame lense ?
Liked in: 129 posts
Re: Autopano giga and full frame lense
by mediavets » Wed Jan 15, 2014 8:21 pm
The D610 is not yet explicitly supported by APG 3.08.
How is APG identifying/displaying the camera and crop factor?:
yvano
by yvano » Thu Jan 16, 2014 9:33 am
Thank you Mediavets,
you are right: my D610 is not yet supported by autopano giga, I send an email to the developers team...
Anyway I indicated that the camera was a D600 and it worked: excellent detection and very good RMS result
I am reassured, really reassured :)
lumelix
by lumelix » Fri Jan 17, 2014 11:41 am
You can edit the file cameras.txt and add there the 610 like the 600.
See C:\Users\xxx\AppData\Local\Kolor\Autopano Giga 3.0\User\Data\cameras.txt
Regards
Martin
