how to avoid getting odd pixel number width for 360" panos
by gkaefer » Tue Jan 14, 2014 8:04 pm
Following Scenario:
with a 1.7crop sensor I do a 360x180 pano with 18mm focal (lens) and with 31 Images.
I use panoneed head with TC handcontroller recording papywizard Format XML files.
apg 3.0.8 does perfectly use the XML ans does stitch the pano.
BUT in about 50% of my tries I do get panos with a odd number of Pixels in width.
the heigth are less Pixels than representing the 180", because the head does not take the Nadir Image so I can Close the Nadir.
in screenshot you can see apg does state ist a 360x178.18 pano with 21287x10536 Pixels.
PROBLEM: the rendered pano cant be enlarged to fill the empty space with some sort of Color. in my example I used green for screenshot in ptp 2.0
how to force APG 3.0.8 so a 360" pano allways does get an even number of Pixels width?
how can I let APG 3.0.8 automatically enlarge the panos height and fill it up with some sort of Color?
screenshot: the green is the filled up Color of the area from 178.18"-180" and the black part around the green is the panoneed head and also you can see the three legs of my manfrotto 9kg tripod.
2014-01-14 19_49_20-New Project _ Virtual tour generated by Panotour - Internet Explorer.png
2014-01-14 19_49_20-New Project _ Virtual tour generated by Panotour - Internet Explorer.png (173.47 KiB) Viewed 843 times
Re: how to avoid getting odd pixel number width for 360" pan
by mediavets » Tue Jan 14, 2014 8:11 pm
IF the Import wizard respects the APG Global settings then this should work:
by gkaefer » Tue Jan 14, 2014 8:46 pm
Hi Andrew,
thanks! yes this works...
Liebe Gruesse,
