error during the installation on Windows 8.1   [SOLVED] - View the solution
karolski_tomasz
by karolski_tomasz » Mon Dec 02, 2013 9:29 am
during installation, AitoPanoGiga Windows 8.1 PRO at the end of the installation I get the two errors that are seen in the attached file, the przyciśnięiu the "ok" installation continues and the program starts up.
Lionel Laissus
Re: error during the installation of Windows 8.1 APG  [SOLVED]
by Lionel Laissus » Wed Dec 04, 2013 10:40 am
Long story short: The update of win 8.1 has also installed some Autopano components at the same time because a reboot asked by Autopano installation was pending
I had the same problem and this is how I fixed it:
1)Unsintall Autopano
2)Open the registry
3)Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\PropertySystem\PropertyHandlers\.pano
4)Click on .pano key. If I'm right you cannot delete it because the key is owned by TrustedInstaller.
So you have to change the owner to Administrators first.
How to do that
Take Ownership of a Registry Key in Advanced Properties
http://www.eightforums.com/tutorials/2808-take-ownership-file-folder-drive-registry-key-windows-8-a.html
If you did right it will be possible to delete the .pano key
5)Close regedit
6)Reinstall Autopano
karolski_tomasz
by karolski_tomasz » Wed Dec 04, 2013 4:19 pm
Thank You very much, its work :)
regards
Lionel Laissus
by Lionel Laissus » Wed Dec 04, 2013 5:26 pm
it wasn't easy to find out this one
karolski_tomasz
by karolski_tomasz » Wed Dec 04, 2013 5:37 pm
Lionel Laissus wrote:it wasn't easy to find out this one
that's what I thought, the more I thank you for sharing your information, :)
Shery678
by Shery678 » Mon Dec 16, 2013 7:49 am
Great job.
rolly1
by rolly1 » Sun Mar 30, 2014 1:18 pm
hi I have had those messages for the last 3 upgrades of APG on my desktop and laptop cheers Rolly1
Nick Payne
by Nick Payne » Sat Apr 05, 2014 2:35 am
I had the same two error dialogs at the end of the Autopano Pro 3.5 install on Windows 8.1 x64, and I definitely didn't have a reboot pending, as I had just booted the machine up in order to run the install. However, the app seems to installed correctly and runs correctly as far as I can tell. Is there any need to follow the uninstall/reinstall procedure listed in the 2nd post in this topic? What would I gain by doing so?
by Annis » Tue Apr 08, 2014 3:16 pm
Nick Payne wrote:I had the same two error dialogs at the end of the Autopano Pro 3.5 install on Windows 8.1 x64, and I definitely didn't have a reboot pending, as I had just booted the machine up in order to run the install. However, the app seems to installed correctly and runs correctly as far as I can tell. Is there any need to follow the uninstall/reinstall procedure listed in the 2nd post in this topic? What would I gain by doing so?
By following the steps in the 2nd post, you will avoid having the error messages show up again during the installation (if you have to reinstall, or for a future version). Other than that, the software isn't affected.
