Crash when adjusting reference image in APG 3.0.7
marzipano
Liked in: 14 posts
by marzipano » Fri Aug 09, 2013 11:47 am
I detected and optimised a 9 image 360 degree rectangular panorama using Photomatix blended images as input
I added green masking controls to 3 different areas
I then went to deselect the existing reference image to gamma and tried to select a new image for reference
APG crashed with the following panel and no crash report screen was produced
This replicated on 3 different attempts
I am using a 4GB HP Elitebook 8730W under Windows 7 64 bit OS
The panel is shown below
regards
Martin
rival29
by rival29 » Tue Aug 27, 2013 3:37 pm
I get this same error, however it doesn't have to be the reference image to trigger a crash, just modification of the color anchor settings for any of the photos in the list. I noticed that if i go into the preferences and disable texture compression under GPU options, the crash goes away.
gdavidson
by gdavidson » Tue Sep 03, 2013 8:04 pm
I get exactly the same error too - it's quite crippling now. I've been working on 360 by 180 panos shot on a D800 lately and I cannot change the reference image without a critical error with the same error message. The progress bar on the preview window then sticks at "calculating colour constraint".
My only workaround is to disable the "Color level after update" and "Optimize on any anchor change" options on the anchors color mode panel, make the changes, save the project and open it again whereupon the changes I made will be visible. Sadly it always crashes should I click on the Optimize color button after changing the reference image.
I have uninstalled and reinstalled 3.07 but immediately have the same issue using the program's default settings. It doesn't seem to happen on smaller panos with less images.
I was going to revert to 3.06 but discovered I missed it, 3.05 being the next earliest I had.
[update]
I have discovered that the error does not occur if I disable GPU processing in Autopano. I'm using an Nvidia Quadro 5000
Graeme
by mediavets » Tue Sep 03, 2013 8:11 pm
gdavidson wrote:I was going to revert to 3.06 but discovered I missed it, 3.05 being the next earliest I had.
Graeme
You can find earlier versions here:
http://download.kolor.com/apg/stable/history
gdavidson
by gdavidson » Tue Sep 03, 2013 8:16 pm
Thank you for that Andrew - very much appreciated. I'll give that a try!
Graeme
gdavidson
by gdavidson » Tue Sep 03, 2013 8:34 pm
Thanks to Andrew, I have installed 3.06 and I no longer get the Critical Error when working on colour anchors. There seems to be a problem with 3.07 when GPU processing is enabled.
Graeme
by mediavets » Tue Sep 03, 2013 8:40 pm
gdavidson wrote:Thanks to Andrew, I have installed 3.06 and I no longer get the Critical Error when working on colour anchors. There seems to be a problem with 3.07 when GPU processing is enabled.
Graeme
Are you working a laptop?
Laptop manufacturers often fail to offer updated graphics drivers.
See if you can find a update for your graphics driver.
For desktops you can use the video card maker's drivers.
gdavidson
by gdavidson » Tue Sep 03, 2013 10:47 pm
Hi Andrew,
I'm using a Dell Precision T7500 workstation with the latest Nvidia Quadro 5000 graphics drivers. That's not to say there isn't a driver issue though!
I wonder what graphics cards others with the same issue have.
Graeme
by mediavets » Tue Sep 03, 2013 11:11 pm
gdavidson wrote:Hi Andrew,
Graeme
I checked and...it happens to me too - Nvidia 8800 GTS on Windows XP 32-bit, on a Dell T3400.
I think it's a bug.
gdavidson
by gdavidson » Tue Sep 03, 2013 11:16 pm
Thanks Andrew. Glad I'm not alone! Autopano 3.06 hasn't thrown up the error yet so hopefully it's something that crept into 3.07.
Graeme
by AlexandreJ » Wed Sep 04, 2013 8:19 am
This issue has been found and will be solved in next fix release quite soon.
gdavidson
by gdavidson » Wed Sep 04, 2013 7:37 pm
AlexandreJ wrote:This issue has been found and will be solved in next fix release quite soon.
That's great news - thank you!
Graeme
