AGP 3.0.7, Win 8, 64bits - Bug during rendering
Morgan
by Morgan » Fri Aug 09, 2013 1:10 am
This is my bug:
I set a queue of rendering panoramas (most of the time its a normal rendering means one file, but I set also rendering by layers), then sometimes, AGP stop to use 99% of my CPU and slow down to about 9/10% and at this moment I can tell it will never finish the rendering, it's like stuck or hang at a certain stage and will not goes on anymore.
More serious, if I decide to stop or pause the batch renderer it doesn't seem to work and finally I have to close the software. When I close it properly it will warn me the rendering is in progress so it asks me for a confirmation to quit. After that I can wait endlessly but the software will never close, so I have to kill the tasks manually. If I restart the AGP I will never be able to render anything new as it mention a problem like there is not enough memory and/or the panorama has too much pictures...
I reproduced this problem often and I can tell it stops always after the second layers when it's "per layers" rendering.
Please find one screen shot not really useful for you as it's just a screen shot to show you the low CPU load.
Hope it helps you.
Sincerely
Morgan
Liked in: 226 posts
by Destiny » Fri Aug 09, 2013 7:48 am
Hi Morgan..
I had something like this with 3D Studio Max.. I found out that the rendering was actually still working.. It just seemed that it wasn't via the Terminal information.... Often it took a long time to cancel, making me think I might as well have just let it continue.. its seemed to backtrack its process.. My suggestion is... Leave it for a bit longer.. It might spark back into action after a pause.... I am not suggesting that it will work, but it will be worth a go....
Morgan
by Morgan » Fri Aug 09, 2013 8:47 am
Hi Destiny,
I queued 12 panoramas, and 10 of them where finished in less than 3 hours, and the 2 last one were still rendering after more than 8hours work :-) So I think I'm quite patient before to kill the task especially because all the panoramas have the same characteristics.
Thanks anyway.
Morgan
