Autopano Giga - Editor - multiple CPUs?
Hellkeeper
by Hellkeeper » Wed Aug 07, 2013 4:36 pm
right now I'm editing a new 80 Gigapixel 360° Pano - and as with the last one - the Editor Window / CP Editor, ... are TERRIBLY slow. I do one click - wait a few Minutes and can do the next click.
I'm running APG on a HP z420 with 6-core (+6 HT Cores) XEON with >40GB RAM. I noticed that only ONE CPU is doing all the work and all other are idling around.
Is the Editor (and CP Editor, ...) only 1 CPU Core capable? Guess there is no chance then to speed up working/editing?
The way it is now it will take days only to add some CPs ... which I desperate need because I shot the Pano from 2 Locations ...
Thank you
Andreas Schnederle-Wagner
Gigapixel Panos from Austria: gpix.at
by klausesser » Wed Aug 07, 2013 4:45 pm
Hellkeeper wrote:Hi,
Thank you
Hi Andreas!
You surely checked the prefenences/settings, did you!? Can you post a screenshot fro the settings relatd to CPU/Cores/GPU?
by mediavets » Wed Aug 07, 2013 4:49 pm
Thank you
What GPU do you have and is it enabled?
Hellkeeper
by Hellkeeper » Wed Aug 07, 2013 5:13 pm
Settings are here: http://temp.in.futureweb.at/apg-settings.jpg
CPU Overview: http://temp.in.futureweb.at/apg-cpu.jpg
GPU is: ATI FirePRO 4800
by klausesser » Wed Aug 07, 2013 7:23 pm
Handling very large panos better use a graphic-card with at least 4GB VRAM, better more. Speeds up the editor dramatically as i learned
from a guy who put a card with 6GB into his machine.
lumelix
by lumelix » Wed Aug 07, 2013 8:36 pm
Hi Hellkeeper
What happens if you set "only" 6 cores to use in the setting box ?
You have physically 6 real cores in your cpu.
Regards
Martin
by klausesser » Wed Aug 07, 2013 8:51 pm
lumelix wrote:Hi Hellkeeper
Good point, Martin!
Also would i use D: as primary drive for temp. Most free space on it.
Besides: select the fastest drive for temp, make it completely free and use it ONLY for tremp.
With such big files temp can´t get big enough.
The second-fastest drive i would reserve for the system and the app exclusively.
The rest of the drives for storing.
Hellkeeper
by Hellkeeper » Thu Aug 08, 2013 10:36 am
1) would love to have a better GFX in this machine - unfortunately the budget is low at the moment for this project! :-/
2) as for the CPUs - "real" cores and HT cores are presented the same way to the OS - so if I select 6 - APG would have no idea what are the "real" cores and which are the HT cores ... so I guess this won't help at all. As you can see on the Task Manager Screenshot - for the OS/programs - there are 12 cores available. But APG only uses one for Editor / CP Editor ... (which core it chooses changes during time as you can see on screenshot - but never more than one at a time)
3) as for the temp drive - I guess they are pretty correct the way I configured them :)
- Z (223GB free) = OCZ RevoDrive3x2 PCI SSD (1,5GB read/write per Second)
- Y (619GB free) = 2xWD Velociraptor RAID 0
- C (112GB free) = System drive - only as Fallback is others are completely used
Andreas
by klausesser » Thu Aug 08, 2013 11:04 am
Hellkeeper wrote:3) as for the temp drive - I guess they are pretty correct the way I configured them :)
Hi Andreas!
Yes - but 223GB free on the fastest drive i guess is not enough for an 80GPx.
Hellkeeper
by Hellkeeper » Thu Aug 08, 2013 11:05 am
and then it falls back to the second fastest drive - or am I wrong? (first Z then Y and if that's not enough even C)
Andreas
lumelix
by lumelix » Thu Aug 08, 2013 2:12 pm
Hi Andreas
Have you installed the latest Chipset-driver for your machine (Intel C602) ?
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=5228607&prodTypeId=12454&prodSeriesId=5225033&swEnvOID=1093&taskId=135&swLang=18
(Could not see Win8 drivers there!)
Which operating system is running, 7, 8 or Server ?
The blue box in the screenshot above looks like Win8.
What are the BIOS-Settings for the CPU ?
Do you use the latest BIOS ? (Looks like in 03.18 Rev A there are some Multicore- and Win8-fixes)
Btw: When rendering a 20 GPixel pano I saw about 80 GByte of temp data (APG 2.6)
Regards
Martin
Hellkeeper
by Hellkeeper » Thu Aug 08, 2013 2:48 pm
in general - when I work in Editor and CP Editor - APG should use all cores? Is this Fact?
@lumelix - will check out drivers/bios and report back! :) (Working on W8)
lumelix
by lumelix » Thu Aug 08, 2013 5:59 pm
Hi Andreas
Some of the tasks in APG are multicore tasks, but not all.
In the actual version 3.0 eg. the CP optimization, color correction or the geometry analysis looks like they are still singlecore.
In this case, all cores are working but only with partial load.
There were several posts about this theme in the forum.
But zooming, moving, preview and rendering should run in multicore mode.
Sometimes it don't use all the cores to the max because the IO-traffic is the bottleneck.
Btw: I couldn't find real Windows 8-Drivers for this chipset from HP or Intel !?!
Regards
Martin
by AlexandreJ » Fri Aug 09, 2013 8:38 am
Lumelix did say it quite clearly, not all algorithms in autopano are multithreaded, because algorithms cannot always be well converted into a MT version or because it isn't need as a single core version is already quite fast.
Multithreaded (and scales welll):
- control point creation
- ransac
- validation
- rendering => warp
- rendering => blending
Partially multithreaded or doesn't give a good scales:
- optimization
- rendering => antighost ( doesn't scale well with the number of core )
Not multithreaded:
- color correction
- panorama layout calculation, extend, projection limits calculation ( to fast )
Hellkeeper
by Hellkeeper » Fri Aug 09, 2013 10:12 am
alright - so this behaviour is intended! :)
Was just wondering - with activated CP Editor Mode - it takes about 1-2 Minutes to select the 2 Images I want to work with in the CP View.
So:
- 1-2 Minutes for selecting 2 Images for CP Editing
- ~1-2 Minutes for automatic CP recognition
(And with all those operations the CPU usage is about ~8-10% in total, nearly no IO usage and RAM not maxed out ... just using one CPU Core on 100% and 'eating my time' ;-))
Now multiply this with some 100 Images I need to link together ... quite some time ... :(
Guess I just have to take the time ...
Thank you all for the help
Andreas
by klausesser » Fri Aug 09, 2013 11:46 am
AlexandreJ wrote:- rendering => antighost ( doesn't scale well with the number of core )
I mean it scales with the number of processors - does it?
by AlexandreJ » Fri Aug 09, 2013 1:44 pm
Hellkeeper wrote:alright - so this behaviour is intended! :)
So:
I did quote the status on everything internal ( autopano kernel ). This case is about UI.
If you click on one image, there can be a lot of event raising everywhere ( no real compulation, just event ).
When selecting one image, you need to select the right line in the layer editor, change the rounded icon to red, etc.
It can create a lot of events and thus stop the UI thread => this is the issue here.
We know that there is space for improvement in UI management especially when having a huge number of images.
by AlexandreJ » Fri Aug 09, 2013 1:45 pm
Antighost does scale a little. A 2x improvement between mono core and 8 used cores MT version. That's low but still 2x.
foundation
Likes: 3 posts
by foundation » Sat Aug 10, 2013 7:39 pm
I too think the selection of images in the control point editor being slow for the user on large panos.
Hellkeeper
by Hellkeeper » Mon Aug 12, 2013 10:21 am
AlexandreJ wrote:I did quote the status on everything internal ( autopano kernel ). This case is about UI.
ok - I understand.
Hope there will be some improvements in the Future - as this is the Task which costs most of the Time when working with larger Gigapixels. (a few Minutes for every 2 Images we link together using the CP Editor) - which adds up pretty fast! :)
I wouldn't mind if rendering would take an hour more or less - because this is done unattended - but this in fact is eating up *payed work time* of our Staff - so it costs money ;-)
Andreas
