Not enough memory?
xamdam
Not enough memory?
by xamdam » Sun May 12, 2013 8:02 pm
I get this error message when I try to start the rendering of a panorama using AutopanoPro 3.0.5:
[h]What :
- Speicherplatz für die Verwendung von Antighost nicht ausreichend, zu viele Bilder überlappen.
- Applikationsspeichereinstellungen überprüfen, um Parameter gemà¤àŸ der Nutzung einzustellen.
- Wenn Bilder zusammenhà¤ngen, versuchen Sie diese nach Belichtungsschichten zu organisieren. Es kà¶nnte helfen.[/h]
[h]Emit : File: "RenderFinalKicInit.cpp" Line: 488
Catched :Render[/h]
It's a 360° HDR panorama, 347 single images (each only 425x640 px) in three exposure layers. I'm using the "little planet" projection type.
My hardware is a 2.2GHz Intel Core7 Macbook Pro running OS X 10.8.3 with 8GB RAM and about 400GB free space on hd.
How could i fix the problem?
lumelix
by lumelix » Sun May 12, 2013 9:23 pm
Hi
What's the amount of overlapping between the images ?
Which focal length did you use ?
What kind of camera (425x640 Pix?)?
Regards
Martin
by gkaefer » Sun May 12, 2013 10:46 pm
go to Settings->Memory used.
here you've a slider, depending where you slide to the text is chaning and different values are explaining your Limits.
this is combined with the Cache Division Settings...
your Options:
deactivate the antighost
add Memory
or reduce the number of source Images
Change the slider to get values reflecting your number of Images per row
xamdam
by xamdam » Tue May 14, 2013 10:40 am
Tanks for help!
