never aligns on autogiga, what am i doing wrong
mugs
by mugs » Tue Apr 30, 2013 11:22 am
I've been using the canon fisheye 8- 15mm shot only at 8mm, 3 shots at 120* and one zenith shot
but the autogiga software never aligns the images properly, there are always so many errors that i need to fix them on photoshop.
attaching a sample image any reason why the roof is messed up and also the top of the pillar?
any help appreciated.
HansKeesom
by HansKeesom » Tue Apr 30, 2013 11:49 am
What happens when you do 6 shots, every 60 degrees?
Do you have a panohead like the nodal ninja 4?
Do you use a tripod?
Can you upload the sourcefiles as a zipfile to f.e. wetransfer.com?
Regards, Hans Keesom
mugs
by mugs » Tue Apr 30, 2013 11:52 am
yep, the manfroto pano head and tripod, whats the email i should send it too
by klausesser » Tue Apr 30, 2013 12:17 pm
mugs wrote:I've been using the canon fisheye 8- 15mm shot only at 8mm, 3 shots at 120* and one zenith shot
Is your setup of the NPP correct for tthe used 8mm? With zooms you need different NPPs: one for each focal-length when you work indoors (which i count your motif to) I don´t know whether
it´s the same for your Canon 8.15mm - that´s a question of it´s construction.
Check that from some tableau you most likely find on the web.
Did you set all values correctly in APG? Check them again. Sometimes the EXIFs are not correctly interpreted - especially with UWW/FE-zooms
PS - Hans meant to send him the images for trying to stitch them for you.
mugs
by mugs » Tue Apr 30, 2013 12:19 pm
it was all shot on one single focal value of 8mm.
what is the NPP, could you explain a biti more on it
by mediavets » Tue Apr 30, 2013 12:39 pm
mugs wrote:yep, the manfroto pano head and tripod, whats the email i should send it too
Which Manfrotto pano head?
by mediavets » Tue Apr 30, 2013 12:44 pm
mugs wrote:it was all shot on one single focal value of 8mm.
what is the NPP, could you explain a bit more on it
NPP - stands for No Parallax Point - the position at which the camera lens rotates around the entry pupil of the lens on both yaw and pitch axes.
Unless you have your camera lens set correctly at the NPP, and unless you are also using a proper panoramic head, then there is little chance of your getting a good quality stitch.
If you don't know what NPP means then it's very likely that your current setup is not correct which would explain why you are not getting a good quality stitch.
by gkaefer » Tue Apr 30, 2013 6:58 pm
many docs how to set it...
http://www.autopano.net/wiki-en/action/view/Web-Tutorials
mugs
by mugs » Mon May 13, 2013 9:35 am
how do i get the NPP with the canon 8-15mm, if i move the lens back, i can see the pano head in the image. its the manfrotto Multi-row Panoramic Head
by mediavets » Mon May 13, 2013 3:18 pm
mugs wrote:how do i get the NPP with the canon 8-15mm, if i move the lens back, i can see the pano head in the image. its the manfrotto Multi-row Panoramic Head
I am sorry you are burdened with a Manfrotto pano head, but that should not matter - does it appear in the image when you stitch and render a pano?
HansKeesom
by HansKeesom » Mon May 13, 2013 5:52 pm
klausesser wrote:PS - Hans meant to send him the images for trying to stitch them for you.
It is best to send it to yourself and then place the link that is in the mail you receive here on the forum.
But mine is hans@alsofjeerbent.nl
