error trying to emb flash file in web site
semiombra
by semiombra » Mon Apr 29, 2013 4:52 pm
hy guys,
tryng to emb panotour flash file in my web site, I receive back the error you can see here:
http://www.druparosa.it/test-
the first on the top is created following Kolor instructions from wiki:
<object width="100%" height="100%"> <embed src="http://WWW.MY-DOMAIN.COM/VIRTUAL_TOUR/MY-TOUR.SWF" width="100%" height="100%" allowFullScreen="true"> </embed> </object>
the second is just an iframe to the flash file....
1) in case of firefox, the iframe lokks working,
2) in case of chrome, it dosn't
you can find here the iframed file here:
www.druparosa.it/ostra/new/ostra.swf
what the hell is happening? any help pls.......
by mediavets » Mon Apr 29, 2013 5:09 pm
semiombra wrote:hy guys,
Welcome to the forum...
Are the files referred to in the error message uploaded to those locations on your server?
semiombra
by semiombra » Mon Apr 29, 2013 5:33 pm
my server, I uploaded all the folder generatred by autopano to my server so I have a folder containg a subfolder with all the data and the .swf.....
by mediavets » Mon Apr 29, 2013 5:40 pm
semiombra wrote:my server, I uploaded all the folder generatred by autopano to my server so I have a folder containg a subfolder with all the data and the .swf.....
Did you select one of the HTML template options when you built the tour?
If so what's the URL to that HTML file on your server?
semiombra
by semiombra » Mon Apr 29, 2013 5:52 pm
I didn't select any template..... need I?
by mediavets » Mon Apr 29, 2013 7:14 pm
semiombra wrote:I didn't select any template..... need I?
We know that the way the HTML file generated by PTP (when you choose one of the HTML template options) is coded that it will work - so I just want to try and rule in/out your coding as the source of the problem in the first instance.
If you ever wish to create dual-mode, Flash and HTML5, tours then you do need to view via the HTML file generated by PTP, or a customed version of it, because it invokes a script that determines whether to load the Flsh version of the HTML5 version of the tour depending on the detection of the broswer user-agent.
semiombra
by semiombra » Mon Apr 29, 2013 7:49 pm
....... i saved the project includicg the html template......
http://www.druparosa.it/test-.html
now it looks to work........ any way I bought the standard version and I suppose there is not the HTML5 option.....
.... forgetting the quality of the pictures .... do you think it's the right way to go straight to a right final result ...... I mean, I didn't understant if to place there a html template is only a trick or is it the right workflow?
thanks
