AutoPano Giga 3 Crashes when Editor Window Closes ...
pollarda
by pollarda » Sun Feb 03, 2013 4:47 am
This is probably known about since this was in the previous version of AutoPano as well but when I close the editor window, the entire AutoPano crashes. The last time, I was rendering at the same time I was mucking with the editor so that may or may not have something to do with it.
ThomasV
by ThomasV » Mon Feb 04, 2013 11:39 am
Thanks for reporting that. Which version of Autopano 3 do you use (3.0.3) ?
Regards,
Thomas
pollarda
by pollarda » Sun Feb 10, 2013 12:43 am
Yes, I'm using the latest version. But I've been playing with Giga since the 2.x version on a trial basis. I've had this same problem since then so I'm always hesitant to use the editor and when I do, I make sure I finish my stitch before closing it.
ThomasV
by ThomasV » Mon Feb 11, 2013 9:29 am
Did you have the 'Crash reporting window' appearing at crash time? If so,l can you give me a crash id so that I can check the cause of the crash.
Regards,
Thomas
pollarda
by pollarda » Thu Feb 14, 2013 4:31 am
There is now crash reporting window. It simply closes down suddenly. Clearly a pointer is getting hammered somewhere ....
ThomasV
by ThomasV » Thu Feb 14, 2013 9:13 am
Did you upload a crash report? If so, did you fill email or comments field so that I can found it and give you a more detailed answer ?
Thanks,
Thomas
jbohac
by jbohac » Wed May 22, 2013 6:11 pm
did you find any solution. I have the same problem. I am using Autopano Pro 3.0.5 and the Program crashes after the closing of the Editor Window. I don't see any crash report. If you need it, I can upload a screen-cast with the crash.
Thank you very much
Jan
sbright33
by sbright33 » Mon Jul 29, 2013 4:10 pm
Same problem here. Here's my new thread. Anyone found a solution?
Please help!
http://www.kolor.com/forum/t18193-crash-after-edit-and-exit
