Rendering a HRD sphere
leifs
by leifs » Sat Feb 02, 2013 10:20 pm
APG 3.03 on Win7 64bit
I've shot a sphere with a 50mm equiv lens, 92 positions x 3 brackets (-2EV, 0EV, +2EV)
The stacks are processed in Photomatix to 92 output .hdr files
The VRdrive2 has produced a XML-file for the sphere, used for the import plugin.
This is case F from http://www.autopano.net/wiki-en/action/view/LDR_/_HDR_:_How_it_works
The detection is straightforward.
Rendering stops at Antighost (have waited for 20 hours), freeze, it is not possible to stop the rendering using the stop-button. APG process has to be killed.
I picked 16 images out of the sphere and tried it out. No XML import.
It is detected allright and it renders to .hdr slow but without problems.
I can tonemap the .hdr image in Photomatix.
Conclusion:
for some reason or another it is not possible to render this 92 image sphere from .hdr to .hdr on my system.
a subset of 16 images renders OK.
since the software is the autopanoGIGA this should be a piece of cake, and it must therefore be a bug.
Leif
Seitz VRdrive2
DrSlony
by DrSlony » Sun Feb 03, 2013 10:27 am
What system do you have and how much free space on your temp drive?
leifs
by leifs » Sun Feb 03, 2013 10:56 am
DrSlony wrote:What system do you have and how much free space on your temp drive?
system:
Intel i7 980X, 48GB RAM, Win7 64bit, SSD RAIDs
temp-drive
6 SSD's in RAID 0, 105GB free space
Leif
Seitz VRdrive2
HansKeesom
by HansKeesom » Sun Feb 03, 2013 11:14 am
Lefs, do you want me to try the rendering on a 64 GB system? Maybe me it can pull it off.... send me all the files in dropbox preferable.
For you, off course, it is free of charge. Also as I like a heavy duty test ;-)
Regards, Hans Keesom
leifs
by leifs » Sun Feb 03, 2013 11:26 am
btw:
the rendering stops at exactly the same spot everytime: at the "A" in Antighost
watching the Resource monitor there are no disk activity for 19 hours.
Leif
Seitz VRdrive2
leifs
by leifs » Sun Feb 03, 2013 11:31 am
HansKeesom wrote:Lefs, do you want me to try the rendering on a 64 GB system? Maybe me it can pull it off.... send me all the files in dropbox preferable.
I've made a zip package for you, it's 5.4GB :)
I will not try to up it on my home ADSL connection, I will do it tomorrow from my workplace.
Leif
Seitz VRdrive2
HansKeesom
by HansKeesom » Sun Feb 03, 2013 11:34 am
ok I will see it coming.
ADSL normally does round 7 GB upload in 24 hour to my experience so taking it to work will surely be faster :-)
HansKeesom
by HansKeesom » Sun Feb 03, 2013 12:30 pm
Of course, do include the pano-file so it will be just a matter of loading and pressing the render button
leifs
by leifs » Mon Feb 04, 2013 11:17 pm
Want a challenge ? Here is one !
download http://www.lstrand.no/ymse/rinden3bkt.zip
(it is 5.4GB so you can't dowload it to a FAT or FAT32 disk)
the readme.txt:
the sphere was shot like this:
Olympus OMD E-M5
Panasonic Leica 25mm f/1.4
Seitz VRdrive2 (at a 3m pole, not NPP calibrated setup)
shot in RAW (ORF)
processed to TIFF using DXO 8 with calibrated modules for camera and lens
included:
XML-file for import to APG using the VRdrive plugin
.autopano file
276 TIFF images (-2EV, 0EV, +2EV), shot at 92 positions
Leif
Seitz VRdrive2
HansKeesom
by HansKeesom » Tue Feb 05, 2013 9:33 am
will try it on one of my 8 core xeons, hope 64 GB will deal with it. Will just do the rendering based on the pano file. Starting time is NOW.
HansKeesom
by HansKeesom » Tue Feb 05, 2013 10:27 am
within the hour things are rendering. 8 Xeon cores at 100% and memory at 6GB used. Keep you posted
HansKeesom
by HansKeesom » Tue Feb 05, 2013 10:47 am
10:47 progress bar is past the word antighost so seems like getting further......10:47 now even at blending
HansKeesom
by HansKeesom » Tue Feb 05, 2013 11:13 am
11:13 and done. will place a link here to the result once it is uploaded to dropbox.
C:\temp\[Group 0]-p1200096_p1200555-276 images.psb ( 3.61 GB )
276 images
Size: 44080 x 22040
FOVRMS: 4.00
Lens: Standard
Projection: Spherical
Color: None
Total benchmark time: 39 min:15 s
Computer description
Operating System : Microsoft Windows Server 2008 R2 64-bit SP1 | 10-240-15-11
CPU Description : Intel(R) Xeon(R) CPU E5-4650 0 @ 2.70GHz
CPU cores : 8 used / 8 total
Memory total : 64 GB
Memory used : 58.1 GB
Optimization benchmark: 37.8212 ms
Local approach: 0 ns
First optimization: 0 ns
Final optimization: 0 ns
LDC/MV: 0 ns
Previewing benchmark: 41.315 s
ComputePosition: 174.179 ms
RenderPieces: 40.9485 s
ColorEq: 1.04986 us
Blending: 173.011 ms
Rendering benchmark: 38 min:33 s
Initialization: 164.925 ms
Warping: 18 min:18 s
Cutting: 56.2688 s
Blending: 16 min:35 s
Saving: 1 min:22 s
Temporary data read/write: 30.6 GB/29.2 GB
leifs
by leifs » Tue Feb 05, 2013 11:24 am
can you render it to .hdr output ?
Leif
Seitz VRdrive2
HansKeesom
by HansKeesom » Tue Feb 05, 2013 11:35 am
Hi Leifs,
That is not how you set it in the .pano-file........ no problem though, I can rerun it to your specs.
Please send me the .pano file with the rendering settings how you want them exactly. If you press apply instead of render they should be saved. then mail the file to hans@alsofjeerbent.nl
Or is it just a matter of changing selecting HDR instead of exposure fustion?
by gkaefer » Tue Feb 05, 2013 4:13 pm
what Is unclear for me:
you mention to go for hdr to hdr workflow using case F.
but in your zip file only tiff source files are included but not .hdr files....
PS: started my test rendering the tiffs to hdr output on my win764bit on 16GB Ram at 16:10...
(used the .pano file to open nothing changed using the exposure fusion preset )
HansKeesom
by HansKeesom » Tue Feb 05, 2013 4:24 pm
Hi Georg,
I did the same for the second run. Started a bit earlier then you.
Progressbar at 3/4 now using 59 GB and no harddisk I/o. CPU at 75 % and no change in memory used by APG, this is a scary time. Will it just hang like this or in the end finish the job. Don't feel like waiting 20 hours for this. Normal rendering finished in 39 minutes so HDR should not be 30 hours....or will it?
Running at 64 GB I think I have a better chance of finishing the job, but we will see ;-)
HansKeesom
by HansKeesom » Tue Feb 05, 2013 4:42 pm
stopped the process and changed cache division to 4 MB. APG seemed to be hanging in Antighost, 75% cpu and no disk i/o or change in memory use.
by gkaefer » Tue Feb 05, 2013 5:35 pm
after one hour I'm still in antighost step and CPU and also discaccess is variable used. in general 8 CPUs 15-30% in use and I can clearly hear access to my RAID1 where I places the tiff source files...
currently nealry 1/3 of the progressbar done...
by klausesser » Tue Feb 05, 2013 6:09 pm
gkaefer wrote:after one hour I'm still in antighost step and CPU and also discaccess is variable used. in general 8 CPUs 15-30% in use and I can clearly hear access to my RAID1 where I places the tiff source files...
Both of you would have finished for quite a time if you had used Photomatix before stitching . . . :rolleyes::cool:
by gkaefer » Tue Feb 05, 2013 6:18 pm
klausesser wrote:Both of you would have finished for quite a time if you had used Photomatix before stitching . . . :rolleyes::cool:
but sometimes it's the challenge that bites ;)
by klausesser » Tue Feb 05, 2013 6:36 pm
Yeah - i bet! ;)
HansKeesom
by HansKeesom » Tue Feb 05, 2013 6:43 pm
I doubt it, the machine took 1,5 hours without me having to do anything. Not even having to select things in Photomatix
E:\\[Group 0]-p1200096_p1200555-276 images.psb ( 14.4 GB )
276 images
Size: 44080 x 22040
FOVRMS: 4.00
Lens: Standard
Color: None
Total benchmark time: 1 h:31 min:22 s
Memory used : 60.0 GB
Optimization benchmark: 32.9169 ms
LDC/MV: 0 ns
Previewing benchmark: 36.4793 s
ComputePosition: 174.622 ms
RenderPieces: 36.1355 s
ColorEq: 979.724 ns
Blending: 148.94 ms
Rendering benchmark: 1 h:30 min:46 s
Initialization: 163.576 ms
Warping: 17 min:9 s
Cutting: 15 min:16 s
Blending: 46 min:22 s
Saving: 2 min:59 s
Temporary data read/write: 208 GB/111 GB
by gkaefer » Tue Feb 05, 2013 7:40 pm
HansKeesom wrote:I doubt it, the machine took 1,5 hours without me having to do anything. Not even having to select things in Photomatix
lol - I think you misunderstood the intention - or did I yours :/ - you will say 1.5.hours in your test render you finished the job with APG?
instead of loading 275 images into apg, bracket them in stacks and then let apg do the work...
... in same time but with success...
it would be possible to create hdr images in photomatix and than load the single 92 hdr files into apg and render to a hdr pano.
PS: still at same place stuck in my test render 1/3 of progress bar around the "?" icon...
CPU is still active 20% in average per core.
in my case it would be more timeefficient to use the photomatix road... (now 3.5 hours for 1/3 in progressbar and no clue if it can be finished with apg)
HansKeesom
by HansKeesom » Tue Feb 05, 2013 8:01 pm
Hi Georg,
Of course there are ways to do things faster, certainly when doing it on a machine with less memory an cores then my VM-machine.
I took the request of leifs in a simple way, just load the pano-file and render it.
This to test the virtual machine.
On my own local machine I would certainly have to do things differently, but that would cost also more manhours/minutes behind the computer.
Haven't seen the result itself yet visually. Not sure whether a 14.4 GB file will load at my 16 GB real workstation
