APP 3.0.3 64bit Mac- Canon EOS 6D files are stitching pink
mattbresler
by mattbresler » Tue Jan 22, 2013 6:07 pm
So I just plugged the .cr2 files in from my 6D into APP and they are rendering pink, similar to the 5D mark III issue from a while ago. They are full raw files not mRAW or sRAW. Jpegs, as always, work fine.
ThomasV
by ThomasV » Thu Jan 24, 2013 10:17 am
Issue 1743 created for this issue.
Could you please upload a sample file to our ftp server (http://www.kolor.com/forum/t766-ftp-server) ?
Regards,
Thomas
mattbresler
by mattbresler » Thu Jan 24, 2013 7:57 pm
[for the public] Files have been sent.
Michael Ezra
by Michael Ezra » Sat Jan 26, 2013 6:11 pm
PhotoDr
by PhotoDr » Sat Jul 06, 2013 1:38 am
I have the same problem, I'm guessing I have to upgrade to a newer version or export them as TIFF first.
Will there be an upgrade for V2 to fix this?
by mediavets » Sat Jul 06, 2013 9:25 am
PhotoDr wrote:I have the same problem, I'm guessing I have to upgrade to a newer version or export them as TIFF first.
Are you asking whether there will be further updates to V2.x of APP/APG?
If so, then no. The upgrade is V3.x.
But you'll probably get better results processing your RAW images before stitching anyway.
