[APG 3.0.2 64bit Windows] Selection of images for gigapan import
Aeriscera
by Aeriscera » Sun Jan 13, 2013 5:33 pm
I just tried to import a 6 image gigapan and the program failed to open the images I selected.
The first screenshot shows me selecting IMG_3196_7_8.tif, IMG_3199_200_201.tif, IMG_3202_3_4.tif, IMG_3214_5_6.tif, IMG_3217_8_9.tif, IMG_3220_1_2.tif. The second screenshot shows what happened after I pressed Open: the list of the names of the opened files is right, but it has not opened the right files. You can't tell, but I can see by looking at the images in the gigapan import preview that the first image is not IMG_3196_7_8.tif. The third screenshot confirms that the files that the program has opened are not the ones I told it to open (the first image in the group is IMG_3184_5_6.tif which is not one of the files I selected).
How difficult is it to get this right? :(
by gkaefer » Sun Jan 13, 2013 6:38 pm
Aeriscera wrote:I just tried to import a 6 image gigapan and the program failed to open the images I selected.
and how would it be to use no special characters for your filenames and here in special for paths/folders? try it without comma (first screenshot).
Just use a-z or A-Z or minus or underscore.
by gkaefer » Sun Jan 13, 2013 7:42 pm
I can not rproduce it:
I did create a folder named "3 Church-48, fake hdr" on my disc and I did move randomly some jpgs to this folder and renamed them to
IMG_3196_7_8.tif
IMG_3203_3_4.tif
IMG_3214_5_6.tif
IMG_3217_8_9.tif
IMG_3220_1_2.tif
and some other image I renamed to other names you used in your screenshot above, also the IMG_3184_5_6.tif.
using the gigapan import wizard I could not reproduce your case that any image of above list was replaced by another image of the same directory.
I also used 1,2,3 rows in gigapan import wizard without diferrence...
so the comma and the space is on my win7/64bit with my autopano giga 3.0.2 no problem.
(I did not have PS and BR opened and in case of BR accessing the same files)
ThomasV
by ThomasV » Wed Jan 16, 2013 9:24 am
We indeed found a mistake on image loading. Issue 1724 opened.
Regards,
Thomas
