[Autopano Giga 3.0 APG Win 64] Drag and drop stops working
thelordsmurf
by thelordsmurf » Sun Dec 16, 2012 6:52 pm
Wanted to submit this bug.
When APG 3.0 is first started, you can drag and drop pictures into the groups window on the left and it accepts them into a new group. However, once you've done that once per session, trying to drag and drop a folder or pictures doesn't work (it doesn't accept the dragged photos). If you close APG and restart, it again lets you do it once. Could you please look into this? It's very helpful to be able to select a few pictures from a folder and drop them into a group.
Thanks!
by gkaefer » Sun Dec 16, 2012 9:01 pm
I cant reproduce it with 3.0 giga final on win7 64bit.
I can add more than once images to one group using drag and drop (from windows explorer to autopano image group).
I can drag and drop more than once images from one group to another group inside autopano .
what I cant do is to drag and drop images containing names already used/existing in the autopano image group
I did test it with png, jpg, hdr and tiff files. I also could mix images dropping tiffs to hdr image groups.
hmm..
ThomasV
by ThomasV » Mon Dec 17, 2012 9:40 am
There is indeed a vicious drag'n drop bug... Fortunately, this one will be fixed in the coming soon bug fix release!
Thanks for pointing that out.
Regards,
Thomas
rodlaird
by rodlaird » Wed Jan 16, 2013 8:03 am
I have just installed 3.02 on an x64 windows 7 system.
Cannot drag files or folders into APG at all. (Could not in 3.0 either)
Bummer
Rod in Oz
_____________________________________
NodalNinja5 Nikon D4 14-24-70-200mm f/2.8 85mm f/1.4 i7 6 core watercooled @ 4.2GHz 32GB 2100MHz DDR3 GTX570 1GB W7 x64
