APG3.0 Mac Vertical Correction
con
by con » Thu Dec 13, 2012 12:41 pm
the vert correct button is 'low-light' i.e. unavailable for a single row pano I'm creating. I recreated the pano with 2.6.3 and it work fine with vert correct option.
ThomasV
by ThomasV » Thu Dec 13, 2012 2:35 pm
The vertical line tool is only available in Spherical and Planar projections. Previously, it was also available for other projection modes, but with incorrect results. That's why we disabled it. So if you want to use it, just select Spherical or Planar projection, use the vertical line tool, and go back in the desired projection.
Regards,
Thomas
con
by con » Thu Dec 13, 2012 3:57 pm
aha, thanks :D
