2 bad things about autopano
pavka
by pavka » Sat Mar 17, 2012 9:44 pm
Hi ;-)
1. When i run the program, choose settings , optimalization , NPP settings... i save it and exit... when i open program again and try to load new photos there is no npp option enabled /it should be i think becasue all other changes are saved/
2. there is some bad thing about output pano... i never used ptgui full version only few version of trials.. and i choose APG.. but today i test ptgui and...why so visible diffrence??
source files JPG
default stiching on both programs
DrSlony
by DrSlony » Sun Mar 18, 2012 6:15 pm
Witam
1- Which settings? There are global settings, and there are panorama-specific settings. I think you probably changed the panorama-specific ones instead of the global ones... if I understand the problem correctly.
2- What bad thing? Looks like PTGUI did some sharpening. If you think that it was actually APG that blurred it, then I suggest you load two TIFF photos into both APG and PTGUI, set planar (rectilinear) projection, render the full-sized pano (100%), and compare it there. Is PTGUI's pano sharper than the source JPEG? Is APG's pano more blurred than the source JPEG?
