[APG2.6.2 RC2/W7x64] crash when trying to render huge 360° g
Hellkeeper
by Hellkeeper » Thu Feb 16, 2012 9:10 pm
Hi there,
APG always crashes when I try to render my 360° gigapixel.
This is the error message: http://temp.in.futureweb.at/autopano/360/crash.jpg
How can I convince APG to render this pic?
Thank you
Andreas
Gigapixel Panos from Austria: gpix.at
renan
by renan » Fri Feb 17, 2012 10:05 am
You exceed current APG limitation (about 500 000 pixel for the width).
But it's just because default memory settings have this limitation. Algorithms are able to render this panorama. We will found a way to remove this limitation in RC3.
Hellkeeper
by Hellkeeper » Fri Feb 17, 2012 10:09 am
so even an upgrade to 32GB RAM would not solve this problem immediately?
Would be great if you could incorporate a solution in RC3 for this - can't wait to see the pano rendering! ;-)
Andreas
renan
by renan » Fri Feb 17, 2012 10:51 am
Unfortunately memory upgrade will not remove this limitation.
Hellkeeper
Re: [APG2.6.2 RC2/W7x64] crash when trying to render hughe 3
by Hellkeeper » Mon May 12, 2014 6:17 pm
Hey there,
just tried to render a Gpix with a Size of 592.453 x 86.010 Pixel and encountered the same problem as described above. With Version APG 64 3.5.1
As I already was able to render Images up to much bigger sizes (>900.000 Pixel) in Version 3.x - is this Limitation back in Version 3.5.x?!?
Andreas Schnederle-Wagner
HansKeesom
by HansKeesom » Mon May 12, 2014 6:29 pm
Hellkeeper wrote:Hey there,
so let's save in old format and render in 3.0.8. right? As the farmer said : when things don't go the way they should, have them go the way they will.......
by AlexandreJ » Tue May 13, 2014 9:35 am
Hellkeeper wrote:just tried to render a Gpix with a Size of 592.453 x 86.010 Pixel and encountered the same problem as described above. With Version APG 64 3.5.1
In rendering engine, nothing changed between 3.0.8 and 3.5.1. The detection / optimization engines has changed, not the rendering.
To be able to render gigapixels, you need to care about the cache size in general setting. This influence a lot the maximum size of the panorama or the number of overlapping images allowed by antighost.
Go to general setting, see the value there and play with it, it will inform you about the max size and max antighost doable with your computer.
Hellkeeper
by Hellkeeper » Tue May 13, 2014 10:03 am
Hi AlexandreJ,
that's weird ... I tried it with "Auto" and all possible Cache Settings ... mhhh
But now as you say ... I can remember setting the Cache Size in old Version direct in the registry because of some Problems I had ... (cacheBlocSize) - guess I will set it in 3.5 registry location the same I have it for 3.x
Andreas
by AlexandreJ » Tue May 13, 2014 1:05 pm
No, we don't share registry between versions
- 3.1.2 has the same registry as any 3.1.X version
- 3.1 doesn't share the registry of 3.2.X, 3.3.x, etc
Hellkeeper
by Hellkeeper » Tue May 13, 2014 1:20 pm
AlexandreJ wrote:No, we don't share registry between versions
That's why I wrote I will try to adjust this Reg setting the same I had in 3.x ;-)
But I just saw that I have 3.x set to AUTO too ... maybe the reg change was lost earlier ... mhhh
Just tried to open the Pano in 3.x to see if it renders there - but 3.x refuses to open 3.5 Files - any way to safe the Project File in 3.x compatible Format?
Andreas
by mediavets » Tue May 13, 2014 2:30 pm
Andreas
You can save in the old .pano format:
Hellkeeper
by Hellkeeper » Tue May 13, 2014 3:19 pm
mediavets wrote:You can save in the old .pano format:
Have been blind ... thx ... will try with 3.x ;-)
Andreas
HansKeesom
by HansKeesom » Tue May 13, 2014 7:52 pm
Andreas
I have good hopes.....let us know how you went.
Hellkeeper
Re: [APG2.6.2 RC2/W7x64] crash when trying to render huge 36
by Hellkeeper » Wed May 14, 2014 9:24 am
Well - won't render too ...
I just don't get is - as I already rendered a 900.000px width Gigapixel in 3.0.8 ... why does this give me such Problems?
I have to reduce with to 499.999 and it works ... but not full size?!?
by AlexandreJ » Wed May 14, 2014 12:46 pm
We don't have such internal limit.
Can you screenshot your general settings ?
http://www.autopano.net/wiki-en/action/ ... _-_General
HansKeesom
by HansKeesom » Thu May 15, 2014 12:34 pm
feel free to forward the whole panorama so I can try on a 64 GB machine for you to see if it renders.
by AlexandreJ » Thu May 15, 2014 1:55 pm
So it seems that on your hardware, you need a cache block size of 16MB to be able to render that panorama of 900K in width.
But the drawback is that a single line in the panorama should not contains more than 1000 images => means that in gigapan shooting style, you should not have more than 500 columns ( on the zone where two rows are covering each other, you'll have 1000 images even with 500 columns ).
One solution, switch to ISO cutting for antighost that doesn't have these limitations, but it is not as good as the other one.
Hellkeeper
by Hellkeeper » Thu May 15, 2014 3:00 pm
@HansKeesom - thx for the offer - but it's not "that" important - we only lose some 10k of resolution ... hehe (and it would be quite some GB to transfer ...)
@Alexandrej - alright - I will try with 16MB - maybe I got more luck this time ... (need to check how many Columns I got)
But should "AUTO" not automatically choose the right setting?
Andreas
HansKeesom
by HansKeesom » Thu May 15, 2014 8:32 pm
I have a 200 GB dropbox ;-) How about you ;-)
But sure, if it is only about 10K it is not worth to try
Hellkeeper
by Hellkeeper » Fri May 16, 2014 10:13 am
alright - it will render if I set it to 16MB ... mmhhhh (maybe I missed 16MB with my tests?!?)
But why won't set AUTO the "correct value" of 16MB? What's the purpose of AUTO if it won't select the right settings? ;-)
Andreas
by AlexandreJ » Fri May 16, 2014 10:23 am
Auto is selecting 8MB as your computer fits more with 8MB ( a little low in RAM for antighost ).
Note: we studied the fact of selecting the mode according to panorama you want to render just before making the rendering.
It was complicated and implied to have a separate executable just for the rendering. So this executable can launch itself with different settings at each rendering.
Hellkeeper
by Hellkeeper » Fri May 16, 2014 10:32 am
alright - if we put in some more memory AUTO would select 16MB?
Would be very cool if AUTO adjust itself according to the image that is going to be rendered - but as you wrote - not that easy as it seems :)
But as it is working with 16MB I'm fine!! ;-)
Thank you
HansKeesom
by HansKeesom » Fri May 16, 2014 6:35 pm
AlexandreJ wrote:......... to have a separate executable just for the rendering. So this executable can launch itself with different settings at each rendering.
YES, finally. We can give it a lower priority in the taskmanager and have it run in the background. Makes my day!
Please spawn the rendering process with LOW priority!
