Strange Stitching Results with Autopano Gig 64bit 2.6.0
mkintner
by mkintner » Sat Dec 31, 2011 4:00 pm
What would be causing this to happen? When we try the same images in 2.6 we are getting a strange star effect with the rendering however when I use version 2.5.2 the images look correct. Any Ideas?
My machine is: i7 Quad Core, 4.6 GHz, 16 Gigs Ram
Tipjip
by Tipjip » Tue Jan 03, 2012 1:11 pm
I have seen the same behaviour in Autopano Pro 2.6.0. It didn't translate into the actual rendering, though.
Christian
wjh31
by wjh31 » Tue Jan 03, 2012 2:34 pm
Are the images being detected as fisheye if appropriate? Ive seen similar behaviour before when fisheye images had lost their metadata in my pre processing.
by AlexandreJ » Tue Jan 03, 2012 3:07 pm
This is caused by lens distortion not well calculated, but is only visible in the editor. In the rendering, it's not visible.
Issue 1095 opened
mkintner
by mkintner » Thu Jan 05, 2012 3:14 pm
Hmmm, it is actually showing in the rendering. The star points at the top are showing, if tried taking out the extra photos but it still happens. The strange thing though is when I do this in 2.5.2 everything thing is fine even when I play with the images. I just tried use fisheye vs strong and still have the sames results.
redted
by redted » Wed Mar 07, 2012 10:58 pm
I would like to bump this issue to confirm/priotorize this, as well as confirming that it shows in the rendering. See the attachments please. I ran into the issue with autopano 2.6.1
The Pixels/Blocks you see arround were the most lines cross in the middle start fizzeling once you hover different images with a move tool.
Since this might be hardware related: I use a radeon HD5700 Series GPU
I doubt it is connected to lost metadata since all pictures were shot in the same way and it just happens on two of about 40
by klausesser » Wed Mar 07, 2012 11:33 pm
mkintner wrote:What would be causing this to happen? When we try the same images in 2.6 we are getting a strange star effect with the rendering however when I use version 2.5.2 the images look correct. Any Ideas?
Could you make some pictures available for testing? I guess it might be in the settings.
