[APP 2.6 RC1 Mac] - preview not shown
bouscram
by bouscram » Sat Nov 12, 2011 8:39 pm
Another problem on OS X 10.7.2 : the preview isn't shown when a panorama is loaded ; it is true for new panoramas or when loading an old one.
by AlexandreJ » Mon Nov 14, 2011 9:20 am
Issue 998 opened
bouscram
by bouscram » Mon Dec 12, 2011 6:07 pm
Also still present in RC2
kzaugg
by kzaugg » Tue Dec 13, 2011 6:57 am
I am running Windows Vista and have tried RC1 & RC2 and have had the same issue.
Lionel Laissus
by Lionel Laissus » Tue Dec 13, 2011 9:48 am
Have you checked the GPU preview in the global setting ?
Menu /Edit/Settings/Gpu processing/Check/OpenGL/Render
bouscram
by bouscram » Tue Dec 13, 2011 7:30 pm
Good point : it is also blank. But otherwise GPU rendering works fine !...
edit : it is most of the times blank... and when it is, something seems to flicker very very quickly when you switch to the "Render" tab.
Here is the OpenGL info :
OGL Version: 2.1 ATI-7.0.52
Render: ATI Radeon X1600 OpenGL Engine
Vendor: ATI Technologies Inc.
Shader Version: 1.20
MaxTextureSize: 4096
MaxTextureUnits: 8
MaxColorAttachement: 4
MaxRenderBufferSize: 4096
Extentions:
    GL_APPLE_aux_depth_stencil
    GL_APPLE_client_storage
    GL_APPLE_element_array
    GL_APPLE_fence
    GL_APPLE_float_pixels
    GL_APPLE_flush_buffer_range
    GL_APPLE_flush_render
    GL_APPLE_object_purgeable
    GL_APPLE_packed_pixels
    GL_APPLE_pixel_buffer
    GL_APPLE_rgb_422
    GL_APPLE_row_bytes
    GL_APPLE_specular_vector
    GL_APPLE_texture_range
    GL_APPLE_transform_hint
    GL_APPLE_vertex_array_object
    GL_APPLE_vertex_array_range
    GL_APPLE_vertex_program_evaluators
    GL_APPLE_ycbcr_422
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_fragment_program
    GL_ARB_fragment_shader
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_imaging
    GL_ARB_instanced_arrays
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_provoking_vertex
    GL_ARB_shader_objects
    GL_ARB_shader_texture_lod
    GL_ARB_shading_language_100
    GL_ARB_shadow
    GL_ARB_shadow_ambient
    GL_ARB_sync
    GL_ARB_texture_border_clamp
    GL_ARB_texture_compression
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_transpose_matrix
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_blend
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_window_pos
    GL_ATI_blend_equation_separate
    GL_ATI_blend_weighted_minmax
    GL_ATI_separate_stencil
    GL_ATI_texture_compression_3dc
    GL_ATI_texture_env_combine3
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_clip_volume_hint
    GL_EXT_compiled_vertex_array
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_object
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_env_add
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_rectangle
    GL_EXT_texture_sRGB
    GL_EXT_transform_feedback
    GL_EXT_vertex_array_bgra
    GL_IBM_rasterpos_clip
    GL_NV_blend_square
    GL_NV_fog_distance
    GL_NV_light_max_exponent
    GL_NV_texgen_reflection
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_edge_clamp
    GL_SGIS_texture_lod
    GL_SGI_color_matrix
Lionel Laissus
by Lionel Laissus » Wed Dec 14, 2011 8:46 am
bouscram wrote:Good point : it is also blank. But otherwise GPU rendering works fine !...
if I'm right the GPU check was ok in 2.6.0 beta 2 ?
bouscram
by bouscram » Wed Dec 14, 2011 10:02 am
I have just verified and you are right... GPU check OK in beta2
Lionel Laissus
by Lionel Laissus » Wed Dec 14, 2011 10:41 am
Actually we fixed some OGL GPU issues in the 2.6.0 RC1/RC2 unfortunately it broke yours :-(
It looks like the "old" cards with old OGL Driver are not very compliance...
So we must figure out a "general workaround" to fix OGL buggy drivers.
Have you installed the latest combo update for your IMAC ?
bouscram
by bouscram » Wed Dec 14, 2011 5:34 pm
I'm running 10.7.2, so I did a full upgrade (from 10.6) quite recently...
Lionel Laissus
by Lionel Laissus » Fri Jan 27, 2012 11:43 am
Did it work better with APG 2.6.2 RC1 ?
bouscram
by bouscram » Sun Jan 29, 2012 8:55 pm
Alas, still the same problems (also those from http://www.kolor.com/forum/viewtopic.php?pid=93879#p93879)
I don't see any change.
