[APP 2.6 RC1 Mac] - two bugs not in Beta 2
bouscram
by bouscram » Sat Nov 12, 2011 7:12 pm
1st problem : the color level histogram is completely wrong (it shows only one or two vertical lines) -> automatic correction is wrong too
2nd problem : the automatic square crop selection is wrong
I have attached screenshots to clarify that. I verified (with the same images) that both problems didn't exist in Beta 2.
Configuration : iMac / OS X 10.7.2
bouscram
by bouscram » Sat Nov 12, 2011 7:37 pm
The screenshots
by klausesser » Sat Nov 12, 2011 7:55 pm
bouscram wrote:1st problem : the color level histogram is completely wrong (it shows only one or two vertical lines) -> automatic correction is wrong too
I cannot second that on 10.6.8!
by AlexandreJ » Mon Nov 14, 2011 9:20 am
Issue 998 opened
bouscram
by bouscram » Mon Dec 12, 2011 6:06 pm
Both still present in RC2 - Well, they are not in the corrections list, so it's not a surprise... The histogram problem is really something which need fixing before the release.
Lionel Laissus
by Lionel Laissus » Tue Dec 13, 2011 9:52 am
Could you send me the pictures ? thx
What is the GFX card of your IMac ?
bouscram
by bouscram » Tue Dec 13, 2011 7:24 pm
I can send you pictures, but the same problem occurs for all the ones I've tried, so I don't think the problem is here.
I have a 2006 Core 2 Duo iMac with a Radeon x1600 graphics card. As I said in the initial post, the problems appeared after 2.6 beta 2, so you should be able to track them in the changes between beta 2 and RC1
by AlexandreJ » Thu Dec 15, 2011 10:11 am
So this is a confirmed bug that we have with x1400, x1500 and x1600 ATI card only.
bouscram
by bouscram » Sat Dec 17, 2011 12:31 pm
I can confirm everything is fine on a Mac Mini (2010 with Nvidia graphic card).
While I can imagine an old machine like mine is not your main target, do you have an idea of when you can fix this ?
wjh31
by wjh31 » Sat Dec 17, 2011 6:34 pm
If it is a graphics card issue, is it not resolved by disabling gpu processing in the options?
bouscram
by bouscram » Sun Dec 18, 2011 6:35 pm
You are right, but 1) GPU processing is really much faster and 2) these bugs are more annoyances than real problems. ;-)
by AlexandreJ » Mon Dec 19, 2011 8:59 am
We ordered this series of ATI card to reproduce the bug here. We have an idea of solution, but it will need to introduce a kind of 'compatibility mode' in GPU option. You'll need to check it to make it work on these GPU series.
bouscram
by bouscram » Mon Dec 19, 2011 4:02 pm
No problem for me to test (except next week where I'm not at home). Let me know when you are ready.
bouscram
by bouscram » Fri Jan 20, 2012 10:31 pm
I just tested APP 2.6.1 RC1, but no change (no so much of a surprise since bug 998 is not listed as fixed)
By the way, is there a way to have a read access to the open bug list ?
by AlexandreJ » Mon Jan 23, 2012 2:05 pm
bouscram wrote:I just tested APP 2.6.1 RC1, but no change (no so much of a surprise since bug 998 is not listed as fixed)
We will propose a GPU compatibility mode for 2.6.2. Should fix the x1600 ATI bug.
bouscram wrote:By the way, is there a way to have a read access to the open bug list ?
It's internal only for the moment. We may open it in read only in the future ( we need to move it to an external server first ).
Lionel Laissus
by Lionel Laissus » Wed Feb 01, 2012 2:28 pm
Good new we fixed that issue by adding a GPU "compatibility (old graphic card)" checkbox
This option will be in the next release APP/APG 2.6.2 rc2
Thx Bouscram for being our guinea-pig for a couple of days !!!!
bouscram
by bouscram » Fri Feb 03, 2012 10:35 pm
You're welcome...
bouscram
by bouscram » Fri Feb 03, 2012 10:58 pm
As I told Lionel by email for the private build I tested, it seems that the "compatibility mode" checkbox is inverted in 2.6.2 RC2 : I need to uncheck it (which should activate the new mode, not the compatibility mode) for the issues to be fixed.
