Autopano Engine v2.6 Beta 4 & nView Desktop Manager
mamoo
by mamoo » Sat Oct 29, 2011 1:40 am
Phenomenon:hangup
To start with Autopano Engine v2.6 Beta 4 enabled the nView Desktop Manager.
Then, Edit-> Setting-> General-> GPU Processing-> Check
next OpenGL-> hangs up and go and Render.
This behavior occurs even Autopano Engine v2.5.
Image is a window to hangup.
What, please tell me if there is good intelligence.
I'm using Windows XP SP3 31bit computers.
Processor : Intel(R)core (TM) i7 CPU
Display Adapter : NVIDIA GeForce 9600GT.
Of course, the driver of the Display Adapter is the latest version.
Arigato.
Blog:http://uhrp.imagefitter.com/
Panogear(FW 020781);BT (Serial COM40);Pw(FW 2.1.20-1);Dell vostro1200(xp sp3)
TouchCP(FW 2.0) Autopano Giga(v2.0.9)
Nikon D300S;Nikkor AF 28-200mm;Nikkor AF-S 300mm
by AlexandreJ » Mon Oct 31, 2011 9:18 am
Issue 970 opened
Lionel Laissus
by Lionel Laissus » Wed Nov 02, 2011 4:15 pm
mamoo
by mamoo » Thu Nov 03, 2011 6:35 am
Hi.Lionel
Result of running the TestOGL
You need a screen shot of the image?
Name: NVIDIA GeForce 9600 GT (VideoController1)
DriverVersion: 6.14.12.8558
OGL Version: 3.3.0
Render: GeForce 9600 GT/PCI/SSE2
Vendor: NVIDIA Corporation
Shader Version: 3.30 NVIDIA via Cg compiler
MaxTextureSize: 8192
MaxTextureUnits: 4
MaxColorAttachement: 8
MaxRenderBufferSize: 8192
Extentions:
    GL_ARB_ES2_compatibility
    GL_ARB_base_instance
    GL_ARB_blend_func_extended
    GL_ARB_color_buffer_float
    GL_ARB_compatibility
    GL_ARB_compressed_texture_pixel_storage
    GL_ARB_conservative_depth
    GL_ARB_copy_buffer
    GL_ARB_depth_buffer_float
    GL_ARB_depth_clamp
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_draw_instanced
    GL_ARB_explicit_attrib_location
    GL_ARB_fragment_coord_conventions
    GL_ARB_fragment_program
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_object
    GL_ARB_framebuffer_sRGB
    GL_ARB_geometry_shader4
    GL_ARB_get_program_binary
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_imaging
    GL_ARB_instanced_arrays
    GL_ARB_internalformat_query
    GL_ARB_map_buffer_alignment
    GL_ARB_map_buffer_range
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_occlusion_query2
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_provoking_vertex
    GL_ARB_robustness
    GL_ARB_sampler_objects
    GL_ARB_seamless_cube_map
    GL_ARB_separate_shader_objects
    GL_ARB_shader_bit_encoding
    GL_ARB_shader_objects
    GL_ARB_shading_language_100
    GL_ARB_shading_language_420pack
    GL_ARB_shading_language_include
    GL_ARB_shading_language_packing
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_border_clamp
    GL_ARB_texture_buffer_object
    GL_ARB_texture_compression
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_multisample
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_texture_storage
    GL_ARB_texture_swizzle
    GL_ARB_timer_query
    GL_ARB_transpose_matrix
    GL_ARB_uniform_buffer_object
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_array_object
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_viewport_array
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_EXTX_framebuffer_mixed_formats
    GL_EXT_Cg_shader
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_bindable_uniform
    GL_EXT_blend_color
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_depth_bounds_test
    GL_EXT_direct_state_access
    GL_EXT_draw_buffers2
    GL_EXT_draw_instanced
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_object
    GL_EXT_framebuffer_sRGB
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_gpu_shader4
    GL_EXT_import_sync_object
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_packed_pixels
    GL_EXT_pixel_buffer_object
    GL_EXT_point_parameters
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_shader_objects
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_array
    GL_EXT_texture_buffer_object
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_add
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_format_BGRA8888
    GL_EXT_texture_integer
    GL_EXT_texture_lod
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_sRGB
    GL_EXT_texture_sRGB_decode
    GL_EXT_texture_storage
    GL_EXT_texture_swizzle
    GL_EXT_texture_type_2_10_10_10_REV
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_EXT_vertex_array_bgra
    GL_IBM_rasterpos_clip
    GL_KTX_buffer_region
    GL_NVX_conditional_render
    GL_NVX_gpu_memory_info
    GL_NV_alpha_test
    GL_NV_blend_minmax
    GL_NV_blend_square
    GL_NV_complex_primitives
    GL_NV_conditional_render
    GL_NV_copy_depth_to_color
    GL_NV_copy_image
    GL_NV_depth_buffer_float
    GL_NV_depth_clamp
    GL_NV_explicit_multisample
    GL_NV_fbo_color_attachments
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragdepth
    GL_NV_fragment_program
    GL_NV_fragment_program2
    GL_NV_fragment_program_option
    GL_NV_framebuffer_multisample_coverage
    GL_NV_geometry_shader4
    GL_NV_gpu_program4
    GL_NV_half_float
    GL_NV_light_max_exponent
    GL_NV_multisample_coverage
    GL_NV_multisample_filter_hint
    GL_NV_occlusion_query
    GL_NV_packed_depth_stencil
    GL_NV_parameter_buffer_object
    GL_NV_parameter_buffer_object2
    GL_NV_path_rendering
    GL_NV_pixel_data_range
    GL_NV_point_sprite
    GL_NV_primitive_restart
    GL_NV_register_combiners
    GL_NV_register_combiners2
    GL_NV_shader_buffer_load
    GL_NV_texgen_reflection
    GL_NV_texture_barrier
    GL_NV_texture_compression_vtc
    GL_NV_texture_env_combine4
    GL_NV_texture_expand_normal
    GL_NV_texture_lod_clamp
    GL_NV_texture_multisample
    GL_NV_texture_rectangle
    GL_NV_texture_shader
    GL_NV_texture_shader2
    GL_NV_texture_shader3
    GL_NV_transform_feedback
    GL_NV_vertex_array_range
    GL_NV_vertex_array_range2
    GL_NV_vertex_buffer_unified_memory
    GL_NV_vertex_program
    GL_NV_vertex_program1_1
    GL_NV_vertex_program2
    GL_NV_vertex_program2_option
    GL_NV_vertex_program3
    GL_OES_depth24
    GL_OES_depth32
    GL_OES_depth_texture
    GL_OES_element_index_uint
    GL_OES_fbo_render_mipmap
    GL_OES_get_program_binary
    GL_OES_mapbuffer
    GL_OES_packed_depth_stencil
    GL_OES_rgb8_rgba8
    GL_OES_standard_derivatives
    GL_OES_texture_3D
    GL_OES_texture_float
    GL_OES_texture_float_linear
    GL_OES_texture_half_float
    GL_OES_texture_half_float_linear
    GL_OES_texture_npot
    GL_OES_vertex_array_object
    GL_OES_vertex_half_float
    GL_S3_s3tc
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_lod
    GL_SGIX_depth_texture
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_EXT_swap_control
mamoo
by mamoo » Thu Nov 03, 2011 6:52 am
Hi.Lionel
PS:
Log of settings while enabled nView Desktop Manager.
Change the image of the test tab is not allowed.
OGL Version: 3.3.0
MaxTextureUnits: 4
Extentions:
    GL_ARB_copy_buffer
    GL_ARB_depth_clamp
    GL_ARB_draw_buffers
    GL_ARB_imaging
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_point_sprite
    GL_ARB_robustness
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_rg
    GL_ARB_timer_query
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_EXT_Cg_shader
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_minmax
    GL_EXT_fog_coord
    GL_EXT_gpu_shader4
    GL_EXT_packed_float
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_lod
    GL_EXT_texture_sRGB
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_NV_alpha_test
    GL_NV_blend_minmax
    GL_NV_blend_square
    GL_NV_copy_image
    GL_NV_depth_clamp
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragdepth
    GL_NV_gpu_program4
    GL_NV_half_float
    GL_NV_point_sprite
    GL_OES_depth24
    GL_OES_depth32
    GL_OES_mapbuffer
    GL_OES_rgb8_rgba8
    GL_OES_texture_3D
    GL_OES_texture_npot
    GL_S3_s3tc
    GL_SGIS_texture_lod
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
mamoo
by mamoo » Sat Nov 05, 2011 9:41 pm
Hi Lionel
The announcement of a system hang when Autopano Engine.
The top image over the Control Panel-> Administrative Tool-> Event Viewer-> Application.
The lower image is the property of the error.
Code is property data(byte).
I hope these tips in solving information.
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 48 61 6e 67   ion Hang
0010: 20 20 41 75 74 6f 70 61     Autopa
0018: 6e 6f 47 69 67 61 5f 77   noGiga_w
0020: 69 6e 33 32 2e 65 78 65   in32.exe
0028: 20 32 2e 36 2e 30 2e 32    2.6.0.2
0030: 30 34 20 69 6e 20 68 75   04 in hu
0038: 6e 67 61 70 70 20 30 2e   ngapp 0.
0040: 30 2e 30 2e 30 20 61 74   0.0.0 at
0048: 20 6f 66 66 73 65 74 20    offset
0050: 30 30 30 30 30 30 30 30   00000000
Lionel Laissus
by Lionel Laissus » Mon Nov 07, 2011 9:17 am
Coud you send me or post TestOGL screenshots with nView enabled and without nView enabled ?
mamoo
by mamoo » Mon Nov 07, 2011 10:34 pm
Hi Lionel
I sent a screen shot and log destination is set to TestOGL.
mamoo
by mamoo » Wed Nov 09, 2011 8:57 pm
Hi Lionel
I tried the Autopano Engine v2.6 RC 1.
The result is good.
Thanks for the quick work.
Arigato!!!
Lionel Laissus
by Lionel Laissus » Thu Nov 10, 2011 10:05 am
GREAT good to know !!
The fix was to workaround an opengl driver bug :-)
