I had some large renderings gobbling up all cpu-power today and tried to pause the rendering so I could get some response from the machine. The CPU-load stayed high from APP even after an hour on pause. What gives? When does it actually pause? Will it have to finish current image in the queue first? (Because that takes 1 day!)
Could you give more details about your panorama and your computer ? number of image, number of cpu etc ...
Because of the new rendering engine "pause" happens only at certain steps of the render. In the case of Gigapixel it could take several hours to really pause the render.
Ahh. Yes it was a gigapixel pano. Rendering-time was over 12 hours so the pause probably hadn't caught after only a few. Another pano took 26 hrs, even worse. It may be a good idea to add a "priority" button to the render so instead of pausing, one can simply push everything to low pri for a few mins (instantly please) while doing other work. Even with quad cores machine can become quite unresponsive with panos both being rendered and detected at same time... Rendering while editing another pano is also quite annoying.
