APP 2.5 will not run
leshalfhill0516
by leshalfhill0516 » Fri Jul 15, 2011 2:39 am
Just purchased AutoPano Pro 2.5, running Windows 7 64-bit. Program will not start up. Crashes at start-up EVERY TIME, with message “AutoPano has stopped working”. I’ve tried running as Administrator, tried using compatibility mode for Vista, tried uninstall/redownload/reinstall, nothing worked. Have I just flushed $100+ ?
by mediavets » Fri Jul 15, 2011 3:49 am
Are you using the 32-bit or 64-bit version of Autopano Pro?
leshalfhill0516
by leshalfhill0516 » Fri Jul 15, 2011 9:59 pm
I was careful to download the 64-bit version both times I've tried it.
by mediavets » Fri Jul 15, 2011 10:26 pm
leshalfhill0516 wrote:I was careful to download the 64-bit version both times I've tried it.
Perhaps it's worth trying 2.6 beta 1?
leshalfhill0516
by leshalfhill0516 » Fri Jul 15, 2011 10:55 pm
Thanks for the suggestion, but I just tried it, and I get the same result.
by mediavets » Fri Jul 15, 2011 10:57 pm
leshalfhill0516 wrote:Thanks for the suggestion, but I just tried it, and I get the same result.
I don't know what to suggest there are many users running APP and APG in 64-bit versions on the Windows 7 64-bit OS.
leshalfhill0516
by leshalfhill0516 » Fri Jul 15, 2011 10:59 pm
Thank you for your suggestion, anyway.
Lionel Laissus
by Lionel Laissus » Mon Jul 18, 2011 11:04 am
Could you "check" (uninstall & resinstall) your GFX driver card ?
Could you try as well http://www.kolor.com/forum/t5923-testogl-readme ?
