windows 2008 R2
eyera
windows 2008 R2
by eyera » Thu Jun 23, 2011 1:40 pm
I have a serious problem. I've just installed windows 2008 server. I've managed to install kolor autopanogiga 64-bit on this system. The problem is that it doesn't work. Does anyone know how to fix this issue?
HansKeesom
by HansKeesom » Mon Jul 04, 2011 2:38 pm
See http://www.kolor.com/forum/t12247-software-does-not-start-on-vmware-windows-2008-machine
Has not been solved yet. Looks like we have a series (of two)
Regards, Hans Keesom
HansKeesom
by HansKeesom » Wed Jul 13, 2011 11:32 am
Hi Eyera,
I tested 2.6.0. RC1 and it runs on my virtual 2008 machine.
Can you test it on yours?
best,
Hans
eyera
by eyera » Fri Jul 15, 2011 1:49 pm
Haven't tried yet. I will test it in a couple of days and will share a small report.
Thanks for advice
Lionel Laissus
by Lionel Laissus » Mon Jul 18, 2011 1:27 pm
This has been fixed in 2.6.0 B1 ....
Workaround :set 1 CPU in your virtual machine (this should be fixed APP/APG 2.5.2 and APP/APG 2.6.0 B1)
HansKeesom
by HansKeesom » Mon Jul 18, 2011 2:11 pm
Lionel,
Eyera did not indicate his problem was on a virtual machine. Mine was.
regards,
Hans
eyera
by eyera » Thu Aug 04, 2011 9:34 am
I've installed APG 2.6.0 B1 on my Windows 2008 system. The result is still the same. Application simply won't launch.
I don't have a virtual machine. I have W2008 installed on a 48-cores computer.
Any advice?
HansKeesom
by HansKeesom » Thu Aug 04, 2011 10:21 am
Hi Eyera,
Say what? a 48-cores machine................wow. Do you happen to have a machine with less cores and same windows version to see if it will run on it.
Can you disable cores in the bios to see whether the software will start with f.e. 1, 2 ,4 of 8 cores?
regards,
Hans Keesom
[Edit :] Are you running 2008 enterprise edition? I am running Windows 2008 R2 Standard which appears to be limited to 4 cores.
