Can not install Gopro VR Plugin
Have a problem using the GoPro VR NLE Plugins? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser les plugins NLE GoPro VR ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
xripunoff
by xripunoff » Sat Apr 21, 2018 8:40 pm
Hello everyone.
Trying to install plugin but fail - even can not mark those boxes in installation window
Win7 Home SP1 64bit
PremiereProCC2015
olivierbo
Liked in: 134 posts
Re: Can not install Gopro VR Plugin
by olivierbo » Mon Apr 23, 2018 10:17 am
I do not know why you cannot install the plugins. Does Premiere Pro installed on the system disk?
Unfortunately, I cannot test with Premiere Pro CC2015 and Windows 7 as I do not have a similar system.
What you can do is to unzip that file to C:\Program Files\Adobe\AdobePremiereProCC2015\Plug-Ins\Common\GoPro\GoProVRHorizon.prm + GoProVRLayers.prm + GoProVRReframe.prm
Let me know if it solves your issue.
Best,
Olivier
GoPro.zip
(1.58 MiB) Downloaded 778 times
xripunoff
by xripunoff » Mon Apr 23, 2018 5:23 pm
Done. Now all files are in specified folder
But I still cann not find this presets in my PremierePro
olivierbo
Liked in: 134 posts
by olivierbo » Tue Apr 24, 2018 9:05 am
So, there are multiple folders which contain the files. Could you copy the 3 .prm files to C:\Program Files\Adobe\Common\Plug-Ins\7.0\MediaCore\GoPro\
Hope this will resolve your issue.
Cheers,
Olivier
xripunoff
by xripunoff » Tue Apr 24, 2018 3:40 pm
Done.
Does not help.
That's what i have in specified folder
21nine
by 21nine » Thu Apr 26, 2018 5:43 pm
Hi, i have the same Problem in PP. I can find the Plugins in AE but it will not work. What is the Problem? I need the Reframe :/ I use CC2017
xripunoff
by xripunoff » Sun May 06, 2018 4:48 pm
So, any actual advice? Still can not use the VR Plugin =(
21nine likes this post.
xripunoff
by xripunoff » Mon May 07, 2018 3:51 pm
So, it is miracle or what, but I updated to 2018 PP and AE, reinstalled the VR plugin and it works! With some issues, but works!
When I create 1080p sequence and apply VR Reframing there is only FOV working correct, other options do not work.
When I create 720p sequence all options work fine. But it's 720p...
I badly need to upgrade the whole PC :/
