GoPro VR plugins not working on 8K footage
Have a problem using the GoPro VR NLE Plugins? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser les plugins NLE GoPro VR ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
troshy
by troshy » Sun Apr 23, 2017 5:40 pm
Hi
I'm trying to use the GoPro VR NLE 'Horizon' plugin with Adobe Premier, and all seems to work fine when using it with 2K or 4K footage, however as soon as I try it with 8K footage in an 8K sequence, the plugin stops working and none of the parameters seem to have any effect. Any ideas what the issue could be?
JeromeL
Re: GoPro VR plugins not working on 8K footage
by JeromeL » Tue Apr 25, 2017 2:52 pm
Thank your for your post, there's indeed a bug with 8k footage. It seems that our effect plugin doesn't work on the GPU, which explains the particularly slow behavior.
We are trying to fix the problem
Regards
