Cannot select Gopro VR Plugins During Install
Have a problem using the GoPro VR NLE Plugins? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser les plugins NLE GoPro VR ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
bmaganic
by bmaganic » Sat Mar 11, 2017 6:28 am
Basically what the title says, the plugins tick box appears, but it simply cannot be selected during installation of AVP 2.6. I'm running Windows 10 64bit. I will attempt to uninstall and reinstall. Is there a limit to how many times I install & enter in my registration key? I've had my computer crash and needed to reboot Windows so I hope when I reinstall Auotopano apps, my registration doesn't count towards some limited number of attempts. Anyways if you're able to help me get the plugins installed, how do I then access them in Premiere Pro?
