Can't find the GoPro VR plugins for Adobe
Have a problem using the GoPro VR NLE Plugins? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser les plugins NLE GoPro VR ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
Miguelsperez85
by Miguelsperez85 » Sat Mar 11, 2017 3:47 am
I'm trying to figure out how to download the vr horizon and reframe plugins for Adobe Premiere.
I have Autopano 2.6
Any help would be appreciated.
JeromeL
Re: Can't find the GoPro VR plugins for Adobe
by JeromeL » Wed Mar 22, 2017 3:45 pm
We identified the problem and are fixing it. We will let you know when the fix version will be available with AVP.
Regards
JeromeL
by JeromeL » Wed Mar 29, 2017 3:09 pm
You can now download the fix version of AVP: http://www.kolor.com/autopano-video/download/
Regards
tanner
by tanner » Wed Mar 29, 2017 4:12 pm
When I download this update, the GoPro logo is now water marked on all of my VR footage in Premiere Pro CC. Any idea on how I can remove this? I own the full version of the software.
EDIT: To fix this issue, simply log into Autopano Video pro and enter your registration BEFORE you open Premiere Pro CC. Problem solved.
