avp 2.5.2 not installing gopro plugins in premiere
Have a problem using the GoPro VR NLE Plugins? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser les plugins NLE GoPro VR ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
joe15
by joe15 » Tue Oct 18, 2016 2:46 am
the installer doesn't install the premiere gopro plugins. when you run the installer it says that the plugins are zero kb. nothing shows up in the effects folder in premiere.
olivierbo
Liked in: 132 posts
Re: avp 2.5.2 not installing gopro plugins in premiere
by olivierbo » Tue Oct 18, 2016 2:26 pm
Can you check if the files are present on the system? Macintosh HD/Library/Application support/Adobe/Common/Plug-ins/7.0/Mediacore/GoPro
Have you checked in Premiere as well?
Kind regards,
Olivier
joe15
by joe15 » Tue Oct 18, 2016 2:51 pm
yea I have checked in premiere nothing is there. also when I try to reinstall it says that the size of the premiere install bundle is zero kb. I have tried downloading on different computers with the same result. it installs the omni importer just fine. is there any way to just install the GoPro vr premiere plugins by themselves because everything else works fine
olivierbo
Liked in: 132 posts
by olivierbo » Tue Oct 18, 2016 2:59 pm
And what about the files on the system? Have you removed previous versions as well?
Olivier
joe15
by joe15 » Tue Oct 18, 2016 4:50 pm
the only thing in that folder is the goprovrplayer.bundle... i have no previous versions
olivierbo
Liked in: 132 posts
by olivierbo » Wed Oct 19, 2016 10:29 am
The files are now located in /Applications/Adobe Premiere Pro CC 2015.3/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/GoPro
Sorry for the confusion.
Also, which version of Premiere Pro are you using. It is compatible from CC2015.
Cheers,
Olivier
