GoPro Omni Importer Not Finding Data
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
4katx
by 4katx » Thu Apr 20, 2017 3:49 am
I keep getting "No Spherical Image Found". I set up CAM1,2,3,4,5,6 but it still wont find the data. Everything is working, is there an update for the software? How can I update it? Anyone else having this issue?
StéphaneG
Re: GoPro Omni Importer Not Finding Data
by StéphaneG » Tue Apr 25, 2017 1:32 pm
can you please clarify what means "set up CAM1,2,3,4,5,6" ?
Does it mean that you copied your files from SD cards to your hard disk drive ? Did you copied all the files ? including LRV and THM files ?
Best regards,
Stéphane
