GoPro Omni Array Error   [SOLVED] - View the solution
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
cgm4967
by cgm4967 » Tue Mar 07, 2017 1:37 pm
Is there a place where the errors are stored so I can figure out what the issue is?
StéphaneG
Re: GoPro Omni Array Error  [SOLVED]
by StéphaneG » Wed Mar 08, 2017 9:57 am
array errors are related to hardware. We have no clue in software to know what's happening in Omni.
I suggest to post your issue on the GoPro's community hub forum.
Best regards,
Stéphane
