Omni + Stereoscopic   [SOLVED] - View the solution
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
cgm4967
Omni + Stereoscopic
by cgm4967 » Sun Jan 29, 2017 7:50 pm
Is it possible to capture 360 with the Omni and then turn this into 3D, 360?
Thanks!
LoicB
Liked in: 8 posts
Re: Omni + Stereoscopic  [SOLVED]
by LoicB » Fri Feb 17, 2017 3:22 pm
Hi, no, the Omni is monoscopic only.
