GoPro Omni Importer not processing the render
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
kad3560
by kad3560 » Tue Jan 24, 2017 3:12 am
I installed the GoPro Omni Importer 2.5.0 and Autopano Video 2.5.3
I've imported my video and am able to preview the footage, however when I click "Start Processing".
After that, kava file is made. But the render isn't proceed.
Status
* movie file is located onto my PC.
* my system is Windows10
StéphaneG
Re: GoPro Omni Importer not processing the render
by StéphaneG » Tue Jan 24, 2017 9:47 am
can you please be sure that you updated Omni Importer according to AVP.
So please try with Omni Importer 2.5.3 and give me your feedbacks.
Best regards,
Stéphane
kad3560
by kad3560 » Tue Jan 24, 2017 10:04 am
I updated Omni Importer 2.5.3. But, the render can't be proceed.
Best regards,
kad3560
StéphaneG
by StéphaneG » Wed Jan 25, 2017 10:47 am
Just to be sure : do you confirm you had selected the desired output format in the option box before clicking on "start processing" ?
If not, the rendering option is set to "Project Only" and to video is produced, only the .kava file
Stéphane
kad3560
by kad3560 » Wed Jan 25, 2017 10:51 am
Yes, I selected 2k for output format.
Best Regards,
kad3560
StéphaneG
by StéphaneG » Wed Jan 25, 2017 10:59 am
Is the .kava file rendered using AVP or not ?
Stéphane
kad3560
by kad3560 » Wed Jan 25, 2017 11:12 am
No, it isn't rendered using AVP automatically. No happen after the .kava file is made.
Manually I can open the .kava file with AVP. But, sync and stitch wasn't proceeded. So, I have to do sync and stitch on AVP by myself as usual(not using omni).
StéphaneG
by StéphaneG » Thu Jan 26, 2017 9:52 pm
With Omni, you dont have to sync your videos because they are natively synced.
If possible can you please record a screencast showing your issue and PM it to me ?
Stéphane
kad3560
by kad3560 » Tue Jan 31, 2017 2:20 am
Thank you for your reply.
Gopro Omni Importer crash during render.(About 30% - 70%)
Actually, I purchesed Rig Alone Packge and updated firmware of gopro hero4 I have according to the following procedure.
https://gopro.com/help/articles/Questio ... re-Updates
Do you think what is the problem?
Best Regards,
kad3560
StéphaneG
by StéphaneG » Tue Jan 31, 2017 8:58 am
If you were able to preview your footage in the Importer, update is not likely to be the issue.
Did you upload the crash report ?
Best,
Stéphane
kad3560
by kad3560 » Mon Feb 06, 2017 2:18 am
Yes, I uploaded the crash report the other day.
Best Regards
StéphaneG
by StéphaneG » Mon Feb 06, 2017 10:06 am
I cannot find any report done with your forum email account.
Can you please PM me the email you used for AVP registration ?
Stéphane
ClaireM
Liked in: 36 posts
by ClaireM » Tue Feb 07, 2017 2:08 pm
Hi kad3560,
Can you try the following workflow and let me know about it :
-> Open the omni importer,
-> Select the shot you want to render and the correct options (2K render as mentioned above)
-> Click on start processing and select the output directory
-> The omni importer should crash at some point as you mentioned earlier.
-> After it crashed, open the output directory and get into the shot directory. You should see your videos as well as the generated kava file.
-> Open the kava file in AVP and try to render it from there. (click on the cog wheel in the tool bar and then hit the render button on the bottom right corner of the pop up window).
Let me know if it crashes as well.
Best,
Claire
kad3560
by kad3560 » Wed Feb 08, 2017 7:45 am
Hi, Claire
I tried to render after open the kava file.
The result it crashed.
Best Reagrds,
kad3560
wheelhouse123456
by wheelhouse123456 » Wed Nov 15, 2017 9:00 pm
We are having this same problem both on Mac and windows 10, where you able to get this fixed?
olivierbo
Liked in: 129 posts
by olivierbo » Wed Nov 22, 2017 4:30 pm
Here is the final version! http://www.kolor.com/2017/11/20/autopan ... than-ever/
Cheers,
Olivier
