Battery solutions for the Omni
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
cgm4967
by cgm4967 » Mon Dec 19, 2016 12:23 pm
We need to take the Omni into the field and are looking for solutions. All I find are Power Adapter for Omni™...and this is a converter I think and then there is the Core SWX XP-L90S V-Mount 98Wh 14.8 VDC Li-Ion Battery...both of theses solutions are about 250 each.
Do I need both of these? Is there a cheaper alternative?
Thanks!
