Still Images   [SOLVED] - View the solution
Have a problem using the GoPro Omni Importer? Have you encountered a bug that needs fixing? Please post it here.
Des difficultés à utiliser le GoPro Omni Importer ? Avez-vous découvert un bug qui doit être fixé ? Postez les ici.
dzeek
Likes: 3 posts
Still Images
by dzeek » Fri Nov 11, 2016 3:10 pm
Does GoPro Omni Importer support still images? If not, are there plans to add this? If not, what is the recommended best practice way to do it? Right now I am doing it manually with Autopano Giga and it is very time consuming and error prone (without the benefit of meta data).
Thank you
Liked in: 442 posts
Re: Still Images
by Annis » Mon Nov 14, 2016 2:33 pm
The Omni Importer doesn't support them yet, but soon!
Until then manually in APG is the only way.
dzeek
Likes: 3 posts
Re: Still Images
by dzeek » Mon Nov 14, 2016 2:36 pm
Annis wrote:Hello and welcome to the forum,
Understood. Can you please provide a rough timeframe for when Omni Importer will support them? Thank you.
skeeterou
Liked in: 5 posts
Re: Still Images
by skeeterou » Sun Nov 27, 2016 5:07 pm
dzeek, the newest beta supports stills!
dzeek likes this post.
dzeek
Likes: 3 posts
Re: Still Images
by dzeek » Sun Nov 27, 2016 5:57 pm
Great. Thanks!
Liked in: 442 posts
Re: Still Images  [SOLVED]
by Annis » Mon Nov 28, 2016 1:48 pm
In case you haven't noticed/ didn't get the newsletters, AVP 2.6 Beta 1 combined with the latest Omni Firmware allows you to stitch still images, timelapses, bursts and nightlapses. :)
viewtopic.php?f=3&t=34157
dzeek
Likes: 3 posts
Re: Still Images
by dzeek » Mon Nov 28, 2016 2:02 pm
Sadly, I have already returned the Omni. I just couldn't justify using it without still image,etc support in the SW and more importantly, the lack of a centralized solution for video and still data offload. Dealing with Micro SD cards is just way too cumbersome.
360jt
Re: Still Images
by 360jt » Mon Mar 13, 2017 4:41 pm
@Annis - "In case you haven't noticed/ didn't get the newsletters, AVP 2.6 Beta 1 combined with the latest Omni Firmware allows you to stitch still images, timelapses, bursts and nightlapses"
Does it open the still images in Autopano Pro or in Autopano Video? Also you said that the latest Omni Firmware is needed, where are the steps to do this, do I need to update each GoPro in the Omni or just the Master?
I have tried the Latest Beta of the Omni Importer and it can't find any of my images.
