Latest Beta 2 is wasting my screen with huge buttons
panoguy
by panoguy » Wed Jul 20, 2016 8:11 am
1. Please can you remove this HUGE Buttons again, you are wasting my screen.
If there is a need for large buttons please make them user adjustable!
2. Please save the last used screen layout and reload it when starting a new session. I'm getting tired to adjust my screen every time I start the tool. The default layout is useless in this format. I'm sitting here in front of a 32" monitor and see HUGE BLUE BARS!
Sitting in front of a 30' monitor and look at this useless screen layout
Thank you
Re: Latest Beta 2 is wasting my screen with huge buttons
by AlexandreJ » Fri Aug 19, 2016 2:47 pm
With that version, we are taking into account the HighDPI mode from windows.
We didn't changed any icons size, it is now your system that does that.
Try to play with that windows setting: https://www.thurrott.com/windows/window ... ay-scaling
panoguy
by panoguy » Fri Aug 19, 2016 10:00 pm
Thank you for the clarification but this is still not really acceptable behavior. I've changed the size scale settings to 125% and then I get a very small display, see screenshot below:
As you can see this size is far to small to read anything without a binocular. The icon size would be fine but the font size is too small.
Setting the scaling to 150% results in the huge scale format as seen below:
Now the Icons are far too large.
I hope you can find a better solution for this problem.
Thank You!
