Rendering ProRes 422 not working as it should   [SOLVED] - View the solution
panoguy
by panoguy » Mon Jun 06, 2016 5:25 pm
I wanted to compare the performance between different codes and was happy to see that to ProRes 422 was faster compared to Cineform format.
Problem is that I can' open the MOV file with Quicktime and also not with Edius 8.
It works fine when I choose ProRes 422 LT ...
ClaireM
Liked in: 36 posts
Re: Rendering ProRes 422 not working as it should  [SOLVED]
by ClaireM » Tue Jun 07, 2016 7:59 am
This is a known issue that is currently being fixed. It should work in the next release. Thanks for your feedback.
Best,
Claire
zmei116
by zmei116 » Tue Aug 02, 2016 9:46 pm
8k Export do not work viewtopic.php?f=124&t=32762
