Short questions about APT/krpano and server space
wjh31
by wjh31 » Fri Sep 03, 2010 7:51 pm
Ive seen a few panos which have been displayed with this software or krpano, and liked the way it looked and felt to navigate, especially with the hotspots to move between panoramas. On this, i downloaded the trial version of APG (i have full version of APP) and tried APT and again liked it. However a few questions come to mind:
1st: What is the difference between APT and krpano?
Panoramas take up alot of diskspace on the server, especially multi-gigapixel images. This is why i currently upload all my large images to gigapan and use their embedded player, so 2nd question is:
Can APT/krpano read from files hosted on gigapans servers, if not, how do you host the potentially gigabytes of files required for multi-gigapixel panoaramas, and multiple smaller panoramas?
by mediavets » Fri Sep 03, 2010 10:04 pm
wjh31 wrote:1st: What is the difference between APT and krpano?
krpano is a Flash Panorama Viewer controlled via command files in XML format.
APT is a GUI front-end/XML command file generator for krpano.
APOT is currently only available as bundle aith Autopano Giga (APG).
But soon APT will be unbundled from APG and sold as a seprate product.
I don't think so.
Find a hosting service that offers unlimited disk space and data tarrif.
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Sep 03, 2010 10:16 pm
wjh31 wrote:if not, how do you host the potentially gigabytes of files required for multi-gigapixel panoaramas, and multiple smaller panoramas?
Don't forget also it's not so much ! For Paris 26Giga, it's 5Go of files on hard-drive :D
Vincèn
Blog: http://www.skivr.com
wjh31
by wjh31 » Fri Sep 03, 2010 10:20 pm
vincen wrote:Don't forget also it's not so much ! For Paris 26Giga, it's 5Go of files on hard-drive :D
Vincèn
How many individual files was that 5Go? my current host has a hard limit on the number of files more than the total size.
Additionally, does this mean i would have to upgrade to APG and then pay for a krpano license aswell to use it fully?
by mediavets » Fri Sep 03, 2010 10:23 pm
wjh31 wrote:Additionally, does this mean i would have to upgrade to APG and then pay for a krpano license as well to use it fully?
At present, yes.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Sep 03, 2010 10:53 pm
wjh31 wrote:How many individual files was that 5Go? my current host has a hard limit on the number of files more than the total size.
Should not be a problem as tiles are sub-divided in multiple sub-directories :)
Vinc`en
by gkaefer » Fri Sep 03, 2010 11:36 pm
a 2 Gigapixel pano I just playing with has the images placed in 9 subfolders holding together 3255 image slices and in sum 320mb.
