Relative Paths
badders
Relative Paths
by badders » Wed Aug 25, 2010 11:11 pm
I understand how relative paths work and have studied the KRPano forum but I'm stuck on a problem I hope someone can help with?
I can't see how to put the APT generated HTML <embed></embed> code in a page that is not in the same DIR as the SWF. For example:
"www.mydomain.com/1/2/tour.html"
"www.mydomain.com/3/4/tour.swf"
I changed the APT generated <embed src="tour.swf" width="640" height="480"></embed> to <embed src="../../tour.swf" width="640" height="480"></embed>
With the XML files also exported I checked the activity window and I see:
"www.mydomain.com/1/2/tour.html" FOUND
"www.mydomain.com/1/2/tour.xml" NOT FOUND
"www.mydomain.com/3/4/tour.swf" FOUND
I then see a "tour.XML loading error (IO error)" message
I can see the <embed> command is calling the tour.xml BEFORE it moves to the correct (.swf + .xml) directory. My guess is the default directory for the first XML file is set within swfkrpano.js and therefore included within the exported SWF?
If so, is it possible to modify the inbuilt APT swfkrpano.js so it uses %SWFPATH% as a variable to set the correct relative path to the first XML? Or am I completely off the plot? I read on the KRPano documentation there is a default path for the XML directory location which is what I think I need to change?
Andrew Baddeley
Online Shop: http://www.360tacticalvr.com
eBAY Store: http://stores.ebay.co.uk/360tacticalvr
Pano Kit: Nodal Ninja 5 R-D16 + Pentax K5 + Samyang 8mm f/3.5 + Samyang 14mm f/2.8 + Pentax 300mm f/4 + GigaPan Epic Pro
by mediavets » Wed Aug 25, 2010 11:32 pm
Is it impossible for you to have the all the files for a tour in the same directory?
badders
by badders » Wed Aug 25, 2010 11:36 pm
mediavets wrote:Is it impossible for you to have the all the files for a tour in the same directory?
Not for me, but it is for the client....;)
Andrew Baddeley
Adrien F
by Adrien F » Thu Aug 26, 2010 1:50 pm
you should try the simple javascript HTML template AND restrict view to a domain (Licence domains). Then uncomment and edit the
swf.addVariable("xml", "pano1.xml");
, replacing pano1.xml by "../../pano1.xml" or whatever.
badders
by badders » Thu Aug 26, 2010 9:56 pm
Yes! that has worked! Thanks.
Andrew Baddeley
