Permanent Tooltips
badders
Permanent Tooltips
by badders » Mon Aug 09, 2010 2:41 pm
Is it possible in APT to have hotspot tooltips (info bubbles) show all the time? i.e. not only on mouseover?
Andrew Baddeley
Online Shop: http://www.360tacticalvr.com
eBAY Store: http://stores.ebay.co.uk/360tacticalvr
Pano Kit: Nodal Ninja 5 R-D16 + Pentax K5 + Samyang 8mm f/3.5 + Samyang 14mm f/2.8 + Pentax 300mm f/4 + GigaPan Epic Pro
by mediavets » Mon Aug 09, 2010 3:25 pm
badders wrote:Is it possible in APT to have hotspot tooltips (info bubbles) show all the time? i.e. not only on mouseover?
Not directly (at least not via APT GUI) but you can achieve a similar effect via the APT GUI by creating your own 'tooltip' graphics and using them as the hotspot Display/Object(s).
badders
by badders » Mon Aug 09, 2010 3:41 pm
Thanks Andrew! But I don't have this option in my APT 1.1.0 Beta9. Is there a difference between PC and Mac versions?
Ah! I see it's only available with point hotspots...
Andrew Baddeley
