Optimizing online viewing
doceave
by doceave » Sun Jul 04, 2010 7:38 am
Hi there guys
Is there a way to increase the number of block in which the tour can load? My issue arises now as I'm making high res tours for online viewing, and loading times have drastically increased. Additional "levels" of download for given degree of zoom would be great. This possible?
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jul 04, 2010 12:10 pm
Hey,
It's something you can setup in KRPano, but don't think you can setup it directly from AutoPano Tour for now ! Be careful that if you increase too much the simultaneous number of blocks downloaded, it can really slow down computers displaying your visits !
Vincèn
Blog: http://www.skivr.com
doceave
by doceave » Sun Jul 04, 2010 4:54 pm
Many thanks... think I'll wait for APT to release a feature...
by klausesser » Sun Jul 04, 2010 9:14 pm
vincen wrote:It's something you can setup in KRPano, but don't think you can setup it directly from AutoPano Tour for now
You can set it in APT at the boxes "Compute Optimal Sizes" -->> Size (computed) -->> Cutting Size take 512
for panos of about 10000px wide.
I use this setting most of the time - gives sufficient speed.
Check te loading time here: www.360impressions.de
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Jul 05, 2010 5:32 am
Klaus,
I think Doceave speaks about "simultaneous download" parameter you can setup in KRPano, but is not avalaible for now in APT ;)
Vincèn
Adrien F
by Adrien F » Mon Jul 05, 2010 8:21 am
Like Klaus I think he speaks of the number of tiles to download for a view...but I am not certain.
If this is the case then "cuting size" parameter id the one he needs to tweak. The smaller it is, the most tiles you will hae to download, but smaller ones.
doceave
by doceave » Mon Jul 05, 2010 10:04 am
I will do some experimenting and post results of modified tile sizes and some other APT parameters on loading times...
garycleft
by garycleft » Wed Jul 07, 2010 2:47 am
@Klaus,
Thanks, your instructions has helped me figure this thing out. Lol and i have been trying to for over a week! aussie pokies
sjosyula
by sjosyula » Sun Aug 22, 2010 9:20 pm
Cutting size ?
Is that the partial panorama width ?
sjosyula
by sjosyula » Sun Aug 22, 2010 9:25 pm
My panoramas are 360 degrees X 150 degrees. I click on compute optimal size and leave it to the maximum. I tried to alter it by reducing the size to half 1500 pixels aprox. But the output turns out to be a bit blurry.
Well, at optimal size, the size of the swf is about 1.2 MB. Is this a huge size ?
how can I optimize the size ?
Any suggestions ?
I have a dead line - Sept 2nd ...
thanks,
by mediavets » Sun Aug 22, 2010 10:07 pm
sjosyula wrote:My panoramas are 360 degrees X 150 degrees. I click on compute optimal size and leave it to the maximum. I tried to alter it by reducing the size to half 1500 pixels aprox. But the output turns out to be a bit blurry.
No. It's quite small.
Any suggestions ?
thanks,
Do you have a krpano licence?
sjosyula
by sjosyula » Sun Aug 22, 2010 10:15 pm
No, I do not..:/
by mediavets » Sun Aug 22, 2010 10:50 pm
sjosyula wrote:No, I do not..:/
Then APT output resolution is restricted.
