Adding Java Script ads to 360 in Autopano Tour
parisbyphoto
by parisbyphoto » Thu Jun 24, 2010 10:16 am
hi, I am using the B7 Autopano Tour software, with the addition of a KRPANO/KRPANO tools licence. I want to integrate some google ads into the 360. Can you please let me know how this is done?
I have seen them already on other sites where a horizontal banner is displayed in the lower part of the 360 with the option to close the advert.
Thanks.
Adrien F
by Adrien F » Thu Jun 24, 2010 10:59 am
I would add a textfield plugin with the google ads code to the visit.
From Autopano Tour you will need to make a hotspot link to a HTML object containing that code, exporting the xml files and modify the plugin so it is kept through the visit at a fixed position. Eventually remove the hotspot afterward. Just a thought, never tried.
One thing you may be aware of : krpano only enable access to its javascript interface when you specify some limited domains in AutopanoTour Project properties.
Edit :
And welcome to the forum btw! :)
parisbyphoto
by parisbyphoto » Thu Jun 24, 2010 12:02 pm
Hi and thanks for your fast reply! I will try what you suggested.
