Exportin to other formats
riobaird
by riobaird » Tue Jun 15, 2010 1:24 am
Hi All,
I would like to export to formats other than SWF. For example: .flv (a flash format), .mov or .qt (Quick-Time).
Does anyone know how I can do this.
Many thanks,
Riobaird.
by mediavets » Tue Jun 15, 2010 10:33 am
Welcome to the forum...
riobaird wrote:I would like to export to formats other than SWF.
Why?
FLV is a Flash video format and quite inappropriate/irrelevant for panoramic images IMO.
Quicktime is virtually obsolete for panos now.
Pano2VR will allow you to create Quicktime output:
http://gardengnomesoftware.com/pano2vr.php
riobaird
by riobaird » Tue Jun 15, 2010 10:59 am
Thanks for your reply Andrew.
Unfortunately, obsolete or not, I have a site that I need to upload a virtual tour to - the site only accepts certain formats - those that I've listed. I will check out Pano2VR though, but if anyone else knows of a way to export from AutopanoTour to one of these other formats, I'd really like to find out.
Thanks, Riobaird.
by mediavets » Tue Jun 15, 2010 12:12 pm
riobaird wrote:Thanks for your reply Andrew.
I see - if there's no possibility of dragging your client kicking and screaming into the 21st century (and in such cases I always enjoy doing the kicking, and hearing the client's screaming!) then I guess you'll just have to 'punish' that client by passing on to them the cost of Pano2VR which you will need to meet their 'archaic' standards.;)
Thanks, Riobaird.
APT's output is exclusively compatible with the krpano Flash Panorama Viewer - so Pano2VR is the best way to go if you need Quicktime output and it's relatively inexpensive too.
by klausesser » Tue Jun 15, 2010 2:03 pm
Thanks, Riobaird.
You can use the "CubicConverter" - if you use a Mac (you didn´t mention the platform you´re on). It´s cheap, very simple to use and very effective: you import an equirectangular image (that´s what APP/APG renders) into the CC and convert it to equirectangular, cube faces, cylinder, mirrorball or QTVR-movie. Kind of a multotool.
Takes a lot of different image-types and image-sizes.
A word on APP/APG`s output: applications like APT usually take equirectangular images or cubefaces to display as spherical panos.
Cubefaces usually are made from equis. So APP/APG´s output-format is universal.
QTVR is s format which isn´t supported any more. In other words: avoid to use it - hard for me to say so as a long-time Mac-user and user of QTVR for years.
But - as Andrew said :cool: - in the 21 century things are actually based on Flash or on HTML5 in the future.
Makes definitely no sense to use QTVR: clients need to extra install a Quicktime-VR viewer . . . which they widely dislike to do. Flash/Java is installed on more than 95% of all computers as is reported.
riobaird
by riobaird » Wed Jun 16, 2010 2:25 am
WOW! That's great - I'm really blown away by how much help you guys have given me here - really, I am. I've got a lot to think about, and will post something to let you know how I proceed. I may even contact the site, to give them a couple of suggestions on updating themselves.
Once again though, many thanks all the time and effort - really appreciate it.
Riobaird.;):/:cool:
riobaird
by riobaird » Wed Jun 16, 2010 2:26 am
Oh, and as soon as I get a chance, I'll update my profile, so you can all find out some more about me and what I do - for now though, I'm in New Jersey, USA, though I hail from Ireland.
