error download
jackLFLB
Liked in: 8 posts
error download
by jackLFLB » Fri Apr 30, 2010 6:43 pm
Petit souci après avoir chargé une visite virtuelle de trois panoramas liés entre eux par des hotspots. Tout fonctionne en local, et une fois les fichiers téléchargés sur le serveur, les outils de navigation n'apparaissent pas, les vignettes et le logo non plus. Cependant l'auto-rotation fonctionne, les liens en survol pour changer de lieu également quand on clique dessus. D'où cela peut-il venir qu'il manque des éléments? Merci d'avance si quelqu'un sait...
by gkaefer » Fri Apr 30, 2010 7:02 pm
avoid non a-z,A-Z,0-9 characters of any kind.
I for example installed AP under normal folders... personal folder was my familyname.... I used german umlaut et voila same result...
Liebe Gruesse,
by klausesser » Fri Apr 30, 2010 7:54 pm
I don´t speak french good enough - sorry.
jackLFLB
Liked in: 8 posts
by jackLFLB » Sat May 01, 2010 1:25 am
Sorry for having asked it in french... so... The pic doesn't change, does it?
Hello
I have a problem, after having downloaded a tour of three panoramics linked together with hotspots. It works perfectly on my computer, and once the files are downloaded, the navigation tools don't appear, and nor the thumbles and the logo. Therefore, the autorotation works, the hotspots appear on mouse over, the click works perfectly and make the panos change... Where cant it come from that components are missing? Many thanks if someone knows...
jackLFLB
Liked in: 8 posts
by jackLFLB » Sat May 01, 2010 1:35 am
gkaefer wrote:avoid non a-z,A-Z,0-9 characters of any kind.
Liebe Gruesse,
Thanks Georg, does it mean that the file can't be nammed with non a-z, A-Z, 0-9 characters? It is the case.
Better than the pic, you can see the result here, http://www.jack-urvoy.com/jazzclubdesavoie.html
by gkaefer » Sat May 01, 2010 1:55 am
Liebe Gruesse,
In my case it was not the filename itself causing the troubles but the folder containing the imges. foldername had one "à¤" and also spaces...
so your error message shows a path to the files.... do these files exist in exact this named path?
try it redoing the project with characters a-z,0-9 in filenames and paths...
the playbackgroundsound "error" is normal - and if file errors are gone this error will not be displayed anymore. How to solve this (dont know...)
jackLFLB
Liked in: 8 posts
by jackLFLB » Sat May 01, 2010 3:17 pm
Well, I found the error.
Using Dreamweaver I din't remember that a filter avoiding to load "fla" and "png" files on the server was activated. I noticed it when I opened the datafile (jazzclubdesavoiedata file in the present case) in my local files The png files were present among my local files (right column) and were not present among the distant files (left column - on the server) in the "graphics" folder which contains png files (because of the alpha layer).
.png was selected in the filter by default with ".fla" and since i didn't upload png files in the past, I didn't remember about.
Well as we say in french, "l'erreur était juste" which could translated by "the error was right" may be...
Anyway, many thanks to you Georg and Klaus!!!!!
Jack
