SWF file does not run when file double clicked
overthetop
by overthetop » Tue Apr 13, 2010 6:24 am
Hello to all,
I loaded one panorama into AutoPano Tour and exported without embedding.
The resulting "pan15.swf" file does not load when the file is double clicked in ithe folder.
Shoudn't the file just load and play in the flash player?
The file can be grabbed here: http://www.vrmapper.com/KRPano/
Thank you
Jim
Adrien F
by Adrien F » Tue Apr 13, 2010 8:18 am
If you do not embed all the datas in the visit you have to upload the data folder on your server.
You also have to export at least once the pictures.
by klausesser » Tue Apr 13, 2010 12:27 pm
Adrien F wrote:If you do not embed all the datas in the visit you have to upload the data folder on your server.
You also have to upload all.xml files related to your pano.
here´s an example of the structure:
overthetop
by overthetop » Tue Apr 13, 2010 12:44 pm
Thank you for your quick replies. The reason that I ask whether the "pano15.swf" file should run directly in the flash player is our programmer has created a tool that loads a map, allows user to select hotspots, and select controls for the associated XML file. The files are ziped and the end user simply has to click on the file to autorun. The map opens in a flash viewer window, when the user clicks on a hotspot a separate sizeable viewer window opens with the flash panorama. The programmer has this all working using a dummy flash file, however when the "pano15.swf" file is swapped for the dummy file it does not work - the image trys to load and fails. My son was able to open the "Pano15.swf" in Adobe Flash authoring tool, so it seems like a valid flash file. Any additional thoughts would be much appreciated.
