SWF to format for DVD / PS3
doceave
by doceave » Sun Mar 28, 2010 9:29 am
Hi guys... any way of converting our most gorgeous swfs to anything capable of display on PS3 / DVD?
Preferably retaining interactivity...
If not ~ how best to make a video of a VT?
by gkaefer » Sun Mar 28, 2010 2:48 pm
FastStone, Camtasia (both commercial tools, freeware is also available - but forgotten the name....) and other tools can take a video of your PC screen. so you can surf your VT and make a video...
You can viw your VTs with your webbrowser of your PS3. (my test shows its not very fast - dont know if this is the browser or the wifi connection of my SP3 to my internet access....)
you can make a VT with APT by embedding all... saved on a data CD/DVD should be playable on PS3 (not via DVD Film option, but with webbrowser of your PS3 accessing the local media)
PS: freeware: http://camstudio.org/
(and with any video converter you can convert this screencast to "any" destination format of your choice: http://www.any-video-converter.com/products/for_video_free/ )
doceave
by doceave » Sun Mar 28, 2010 3:08 pm
Thanks.. will give the latter a try (PS3 with embedded option)... In this case I just make an HTML with the swf embedded correct?
digipano
by digipano » Sun Mar 28, 2010 4:45 pm
Interactivity will be lost though when you convert to video.
by gkaefer » Sun Mar 28, 2010 10:38 pm
doceave wrote:Thanks.. will give the latter a try (PS3 with embedded option)... In this case I just make an HTML with the swf embedded correct?
yes. I testet both templates html only and java....
