Googlemaps plugin
Marknot
Googlemaps plugin
by Marknot » Fri Mar 19, 2010 3:35 pm
Hello, i would like to know how to add this plug in my xml menu, i've bought today the version on krpano, it's so hard to understand sometimes :rolleyes:.. beacouse i don't understand the way to use krpano/autopano tour togheter!? something can be added to the xml menu something no...i would like to know the best way to add a plugin but usin Autopano tour and the xml menu file.
Thanks in advance.;)
Adrien F
by Adrien F » Mon Mar 22, 2010 11:20 am
Google Maps plugin is not officially supported by Autopano Tour.
However you can still include it in your menu template:
Step 1:
Copy this code to your menu template:
<menu>
        <plugin name="maps"
            url="googlemaps.swf"
            keep="true"
            handcursor="false"
            align="leftbottom"
            x="10"
            y="10"
            width="300"
            height="300"
            key="1234"
            lat="44.959818"
            lng="14.407840"
            zoom="18"
            maptype="SATELLITE"
            dragging="true"
            scrollwheel="true"
            continuouszoom="false"
            keyboard="false"
            crosshairs="false"
            onmapready=""
            onmapmoved=""
            onmapzoomed=""
        <radar visible="true"
               size="100"
               alpha="0.5"
               fillcolor="0xFFFFFF"
               fillalpha="1.0"
               linecolor="0xFFFFFF"
               linealpha="0.0"
               linewidth="0.0"
               glow="true"
               glowcolor="0xFFFFFF"
               glowwidth="4"
               glowstrength="3"
               behindspots="true"
               dragable="true"
        <positioncontrol visible="true"
                         anchor="topleft" x="2" y="2"
        <zoomcontrol visible="true"
                     anchor="topright" x="2" y="2"
                     hasscrolltrack="true"
</menu>
Step 2:
Copy the googlemaps.swf into /Your/Install/Drive/kolor/Autopano Tour/Templates/menu (the same place where you put the xml template).
Step 3:
Run APT and export using your menu template.
Step 4:
manually edit exported xml to add hotspots to the google map.
This plugin needs a google API registration ID to work online.
krpano doc page : http://www.krpano.com/plugins/googlemaps/
Marknot
by Marknot » Mon Mar 22, 2010 2:37 pm
Adrien F wrote:Google Maps plugin is not officially supported by Autopano Tour.
Step 1:
<menu>
        <plugin name="maps"
            keep="true"
            handcursor="false"
            align="leftbottom"
            x="10"
            y="10"
            width="300"
            height="300"
            key="1234"
            lat="44.959818"
            lng="14.407840"
            zoom="18"
            maptype="SATELLITE"
            dragging="true"
            scrollwheel="true"
            keyboard="false"
            crosshairs="false"
            onmapready=""
            onmapmoved=""
            onmapzoomed=""
               size="100"
               alpha="0.5"
               fillalpha="1.0"
               linealpha="0.0"
               linewidth="0.0"
               glow="true"
               glowwidth="4"
               glowstrength="3"
               behindspots="true"
               dragable="true"
</menu>
Step 2:
Step 3:
Step 4:
Thanks, i've make it, but i would like to understand how to put manual hot spot, they're working on synchronism with the other spot created with A.Tour?
Ex. If i click on spot on googlemaps it change pano ... if click on other spot on the tour ( another pano ) the googlemasp will take the new spot or position!?
Thanks in advance
tibor sedin
by tibor sedin » Mon Oct 25, 2010 2:04 pm
I would like to embed PanotourPro Beta GoogleMaps plugin and the instructions here I do not work. Thanks, Tibor Sedin
renan
by renan » Tue Oct 26, 2010 8:50 am
It's may be that, in sample code the google map plugin node is not closed :
the '>' character at the end must be '/>'
